Question about Haier AHD50 Dehumidifier
Haier Dehumidifier HD50-T
Humidistat is broken: contact points are burned beyond repair. The Haier people said they don't have the part and can't recommend anything. Anyone have an idea what part could be adapted to replace this one?
  • Anonymous Mar 23, 2014
    burning smell
  • 105 Answers
A humidistat from a different brand will work, provided it is mounted well & hooked up properly. Make sure the replacement is designed to switch the compressor directly.
Posted on Jul 17, 2007
SOURCE:
Dehumidifier runs continuously and displays higher than normal humidity levels.
Probably some glitch with the sensors. I recommend taking it to a service center.
Dec 06, 2013 | Haier DE65EK 65 Pints eco-Friendly...
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
HD456E dehumidifier shows it is on but nothing happens - no compressor running. The humidity is 75% in basement and have it set to run at 45%. Any possible fix or is it time to replace eventhough it is...
You can normally hear a humidistat open and close if you listen closely. Also, the water tank has either a float or pressure switch that will shut it down.
Jul 30, 2013 | Haier HD656E Dehumidifier
I just purchaed a DE Series Dehumidifier. The instructions say to press the arrows keys to adjust the humidistat, but whenever I push the arrows the display reads "on". So I don't know what...
It is not abnormal for ON to show up when you first push the arrow up or arrow down button. If you want to lower the humidity press the arrow down button again, once the ON lights up. The lower you take the percentage the more humidity will be removed.
Hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Haier HDN655E Dehumidifier
An E 3 error code comes up and I don't have a manual to determine what the codes mean.
An E3 error code is a Sensor Shutdown Failure. You will need to contact Haier Customer Support for an explanation on which sensor it is and how to solve the problem.
Jul 11, 2011 | Haier DE65EA Dehumidifier
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Not operating properly - doesn't draw water
May 18, 2009 | Haier HD306 Dehumidifier
Dehumidifier does not collect water.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Haier AHD50 Dehumidifier Logo
300 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Bill Long
Evan Benson
Evan Benson
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
