Question about Kenwood Fp912 Fp920 Fp921 Ridged Grey Seal Ring 6809 U
I cant remove the blade unit from the liquidiser jug
I have just bought the mulit pro and want to use the mill but i can't get the blade unit off the jug and the instructions look like it has to twist but this is not working and i don't want to break it.
I used the seal from the lid to hold the smooth base unit. It comes off the lid quite easily (and goes back on again) It took a while but it did eventually unscrew. Good luck!
Posted on Jan 04, 2013
  • Leon vd Merwe
    Leon vd Merwe Apr 04, 2014
    e spares don't keep Salton
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
My blender appears to be leaking from the bottom. Is it likely to be the jug or the coupling to the motor?
It is likely to be the rubber washer on the jug. You will need to disassemble the mixing blades and remove the rubber washer(s) from the jug and take it with you to a Target, Walmart or kitchen store. They usually carry a varity of the washers and you should be able to compare yours to get the right size. Some actually tell you exactly what mixers they fit.
Nov 25, 2010 | Waring 6000CG 60th Anniversary Blender
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
How to know a NEW from the old polycarbonate jug\pitcher that cracks near blades.
The "code" you are seeking is found in the serial number, which has a specific way of noting when the unit is manufactured.
Buy with confidence and hang on to your dated sales receipt. If the blender leaks, take advantage of Kitchenaid's 1 Year warranty by calling into Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
May 24, 2009 | KitchenAid KSB560WH 5-Speed Blender
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Kenwood Fp912 Fp920 Fp921 Ridged Grey Seal Ring 6809 U Logo
587 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
