Question about Poulan Garden
POULAN CHAINSAW DIES UNDER LOAD
STARTS FINE BUT DIES UNDER LOAD
  • 211 Answers
SOURCE: Poulan 295 chainsaw won't start when warm
Hi
Check the spark plug first (when the engine has warmed and died).If you have a good spark,check the fuel pump from the carb(it shuld not to be tighten).If everything is ok check the seals(they are sealing the engine).Good luck!
savumihai71
Posted on Dec 11, 2008
#1 Taper
  • 1041 Answers
SOURCE: Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
Posted on Jun 10, 2009
  • 246 Answers
SOURCE: chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Posted on Jul 26, 2009
  • 583 Answers
SOURCE: Chainsaw idles, goes to high speed for a few
have you looked at the filter in the tank? get a wire hook fish around in the tank it should be on thend of a fuel line inside the tank
Posted on Aug 23, 2009
agent91
  • 2100 Answers
SOURCE: stalls under load
Try opening up the high speed jet, see if it does any better. Turn it just a quarter turn at a time, if opening it up doesn't do anything, try closing it. If that doesn't do it, try closing it down all the way, then open it up 1 1/2 turns, this will put you into run mode, you can adjust it from there. You have 2 screws on the side of the carb, low, high, they are marked, don't be afraid to turn, that is what they are for. Check it out.
Posted on Jun 20, 2010
I HAVE A NEWER POULAN PRO CHAINSAW.STARTS AND RUNS FINE FOR 10-15 min. THEN DIES AND WON'T RESTART UNTILL COLD. THEN IT REPEATS THE SAME PROBLEM.
If it pulls easier than it used to when you try to start, you have low compression. Once the saw warms up, it doesn't have enough compression to run. If that's the case, there is no easy fix, it needs piston rings.
Dec 11, 2016 | Poulan Garden
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
Chainsaw dies under load
how much use has it had and is the bore scored its probably worn needs new piston Rings
Jun 30, 2012 | Garden
Changed filter and fuel lines, poulan 31cc 250E. starts fine but dies when accelarated
My chainsaw was doing this.The carburetors on these small engines have a fuel inlet screen that clogs with tiny bits of debris.Remove the carb,and take the portion off that has the fuel line attached to it(if you're careful,you can reassemble it without needing a new gasket).The screen is about 5/16" in diameter.Spray some carb cleaner in there to clean the screen out.(this is mt best guess,because it sounds like a fuel starvation problem)
May 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Hi
savumihai71
Dec 11, 2008 | Garden
Garden Logo
71 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
