Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
H3000 Motor becomes very hot during use
Do the motor brushes need replacing? I'm afraid I will burn the motor out. I noticed the problem due to the motor smelling hot.
  • 36 Answers
Over heating on a floormate is cuased by obstructions or a clogged up filter. Try running it without the recovery tank. If it doesn't over heat you need to check for obstructions in the nozzle and the tube leading up to the recovery tank. if that is all clear, a new filter should fix it.
If the machine over heats without the recovery tank on it, you might be right. Hoover only sells motor assemblies, not just the brushes. I have never seen them used enough to need new motor brushes simply because of wear. If the brushes are worn down completely, there is probably a short in the motor.
Let me know if this helps.
Posted on Dec 31, 2012
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
Nzero
  • 78 Answers
SOURCE: Self propell doesn't work.
may be a stripped sprocket/cog or snapped shaft. check and replace as needed.
Posted on Sep 03, 2008
  • 10 Answers
SOURCE: Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
  • 294 Answers
SOURCE: No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Posted on Oct 28, 2009
Vac Belts
  • 701 Answers
SOURCE: HI, my motorized brush barely turns.It makes a hot
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Posted on Dec 24, 2009
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My belt is burning do I need anew belt and just align and clean brush. Motor sounds ok
Belts start burning because they've become too worn and loose to keep a good grip on the brush and motor shaft. You do need a new one. When replacing, ensure it's in the correct position by rotating the brush a few times. Make sure you've got the correct amount of tension on it. Too loose and the belt will slip and burn out again. Too tight may cause breakage as well as excessive stress on the motor.
It's often best to allow even a simple fix to be done by a service tech.
Dec 21, 2010 | Panasonic MC-V7720 Bagless Upright Vacuum
Motor burned out need a replacement motor. Where can I buy one?
USAVACUUM.COM has all the hoover parts available for the H3000. The part number is 59177074. Follow the link below to your model number.
http://www.usavacuum.com/category-s/85.htm. .
Thanks. Please leave positive feedback.
Mar 13, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Spin brush will not spin. local repair man said one gear stripped and motor would need replacement. is this correct??
There is a plastic rod that sticks out of the back of the spin brush, this makes all of the brushes rotate. The motor would need to be replaced if it was not turning on anymore. this doesn't sound right...?
I think it is just a broken piece of plastic on the block brush which will need to be replaced.
You can find a schematic and the parts you need on this link
H3000 Link
Feb 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
121 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
