Question about Bodum Granos 3020-16 Espresso Machine
Bodum granos new will not function
New machine but when you turn it on the steam and water lights flash. This is what is suppose to happen when the steam valve is opened yet it does it in the closed position. When you open the steam nob the lights stop flashing but then all you get is hot water/steam no espresso. I opened the back and unpluged the wires that lead to the valve and then the water flows through the head but of course you get no steam.
  • 199 Answers
The connections to the heating coil element looks faulty.check it.
Posted on Jan 18, 2009
How could I fix my machine?
Refer your inquiry and description to Bodum.
May 01, 2014 | Bodum GRANOS (3020-16US) Espresso Machine
Im looking for the operating manual for a Bodum Granos coffee machine please
you can obtain your manual by clicking on this site and following the links to download the manual or to bring you a step ahead to the following page click this link
this site is free to download any manual or instructions and if you have any problems obtaining it through this site message me back along with your email and I will send it to you from my email. Please also remember when our chat has fully concluded to rate how this service has helped in locating your manual for you. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Jan 17, 2012 | Bodum Granos 3020-16 Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
My bodum granos expresso machine leaks from the base. would anybody know why. If not is there somewhere I can send it to be fixed in Canada? Thank you:)
Did you find an answer for this? mine is brand new and leaks from the base. I know its been on the shelf at the shop for 3 years, so I'm expecting its a leaky seal somewhere.
Mar 22, 2011 | Bodum Granos 3020-16 Espresso Machine
All the lamps on the Granos flashes - what does it
Clean it with CLR. I had to turn the steam on and plug and unplug it to get it to work for just a few seconds but that was enough to get some of the CLR into the system. I let it sit overnight and then the next day it would work for 10 - 15 seconds at a time. Finally the more CLR I got into the system the better it worked. I regularly used a coffee maker cleaner but the CLR seemed to break up whatever was in there.
Jan 07, 2010 | Bodum GRANOS (3020-16US) Espresso Machine
Pump activates put coffee does not drip instead it water comes out the top of the pod handle
I had the exact same problem about a year ago. I bought a replacement valve from Bodum here in Denmark, where I live.
The cracked valve was made out of some sort of plastic, but the new one I got was cast in metal.
The machine has been working perfectly since.
Oct 07, 2009 | Bodum Granos 3020-16 Espresso Machine
Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Feb 21, 2009 | Bodum Granos 3020-16 Espresso Machine
I'm having problems with my Bodum granos it is not dispensing water for esspresso or manually. It starts to go through the process it then shoots out alot of steam and then stops. The indicator light...
I had a similar problem and had a techo fix it.  He didn't charge - because the solution was real easy. Basically you have a blocked filter. The filter is at the base of the rear column. You need to unscrew the back plate on the column leading up to the head. Once unscrewed you'll find the filter somewhere at the base end. Remove filter wash, reinstall and screw the thing together. Should now run ok. Cheers
Apr 03, 2008 | Bodum Granos 3020-16 Espresso Machine
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
This is not a fix but it may be a way to at least get an espresso without milk. I opened the panel on the back and removed the to wires at the top of the circut panel. They are both fixed to a plug so all you have to do is gently pull. This turned of the steam/water function and the the water came through the head as it is suppose to. I did not get all the parts with mine so if anyone tries this please post the outcome. Remember to unplug the machine before you open the back. I will post the real fix if I figure it out.
Oct 26, 2007 | Bodum Granos 3020-16 Espresso Machine
Open Questions:
See all Bodum Granos 3020-16 Espresso Machine Questions
Bodum Granos 3020-16 Espresso Machine Logo
321 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
ray gallant
Level 1 Expert
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
