Question about Keurig Platinum B70 Coffee Maker
Keurig b70 water tank leaks out all over the counter
Just refilled water and brewed 2 cups of coffee and a few minutes later all of the water leaked out all over the counter.
  • 1,511 Answers
Shut-off valve failed, retry a second time and it will reset accordingly.
Posted on Feb 06, 2014
SOURCE: Slow coffee stream and smaller brew size with B70
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
Posted on Mar 14, 2009
  • 5 Answers
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
Posted on Aug 12, 2009
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
SOURCE: The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Posted on Dec 27, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
Jul 27, 2014 | KUERIG Keurig Platinum B70 Brewing System
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Mar 14, 2009 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
364 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
