Question about Grilling
How do I repair my relay control on my Masterbuilt smoker?
  • 72 Answers
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
Posted on Nov 09, 2008
SOURCE: Element won't heat on Masterbuilt smoker
I called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and tis working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere. i cant help with this except to say that Masterbuilt customer service says they are negotiating with their supplier to see if they can sell the elements seperatly. they hope to have that resolved by summer.
hope this helps.
D Smith
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
SOURCE: Where to put the wood chips in my gas smoker
you soaked the wood chips in water for about 30 min. shake excess of water and place them on the flame disk bowl right under the water bowl.
Posted on Aug 15, 2010
What is the part number for the controller for masterbuilt smoker model # 20072514
Their support page is at https://www.masterbuilt.com/index.php/support/
Give them a call or Email them with your question on customerservice@masterbuilt.com
I am sure they will help you.
Sep 07, 2014 | Grilling
Masterbuilt 20072612 ERR1 error code
ERR1 MEANS YOU NEED A NEW BODY KIT. PER MASTERBUILT, THE SMOKER IS DEAD AND NEEDS A FULL BODY KIT (BASICALLY THE ENTIRE UNIT)
Apr 18, 2014 | Masterbuilt 20070106 Electric Smoker
I need an element for Mod: 20070106 Ser.# GA040925
You can purchase a new heating element part # 990050051 either from Masterbuilt or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/masterbuilt/
If they are still available. All of Masterbuilt's electric smokers have been plagued with electrical problems.. It's either the element or the electronic controller on the top of the smoker, that constantly fail.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Masterbuilt 20070106 Electric Smoker
My smoker does not smoke at 220 degrees it did fine in colder weather
Either the heating element or the controller on top of the smoker has failed. This is a chronic problem with Masterbuilt electric smokers. That's probably the reason it on has a 90 day warranty.
You can purchase the part(s) from Masterbuilt or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=491507&modelsID=135884&typeName=gas%20grill
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Masterbuilt 20070106 Electric Smoker
After reseting the circuit braker the smoker did not come back on
Hi and welcome to FixYa, I am Kelly
Most likely the heater has failed.
The manual for the 20070106 is on this page:
http://www.masterbuilt.com/manuals.aspx
The element kit is PN: 9907090033 (Est. $45.00)
My thoughts are the element has shorted out. Before ordering read out the element with an ohm meter. Read each terminal to ground with the at least one wire disconnected. Then read the element end to end. You should read resistance end to end but NOT end to chassis.
That is just for the element. You said it did not come back on after resetting the CB. If the display is blank the control panel has failed: Contact Masterbuilt at 1.800.489.1581 (<-Only source)
MASTERBUILT Customer Service at 1-800-489-1581.
Control panel PN: 990050048 Digital Control Panel Kit
Something has caused the control panel to fail... if there is a chassis short some where in the unit you can have a brand new control panel fail. Inspect the wiring and components for signs of damage BEFORE replacing the control panel. Repair any wire damage found. Thee are only 2 components that use electricity; the control panel and the heater. Finding a wiring problem should be simple.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
Smoker was working great. Went to smoke some ribs this morning and my controller won't go above 90. Help!
Your heating element is now probably inop. You'll have to go onto masterbuilt.com and order another element. Try this site:
http://www.masterbuilt.com/pm-smokers.html
Feb 26, 2011 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
141 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
