MY OMNIVS500U NOT CHARGING INTERNAL BATTERY
ONLY 11VOLTS DC CHARGING THE INTERNAL BATTERY
  • 7,627 Answers
Is the battery dead?
Posted on Dec 31, 2012
Generac XP8000E how do you replace the battery charger fuse 1.5 all I can find out is you have to remove the control panel. No manual and can't find any info
Roger,
1st check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC with the engine running.
If you get these results next check the battery. You should get max 13v dc going to the battery. If your battery is not charging on this unit or gets under 12x dc, you need to replace the battery charging rectifier.
http://www.generatorguru.com/battery-charging-rectifier-99302775/
If you need other parts you can find them on this page.
http://www.generatorguru.com/xp8000e/
Hope this is of assistance to you!
Dec 19, 2016 | Generac Electrical Supplies
What could be draining a brand new battery along with having a brand new alternator?
the alternator is not charging
problems include incorrect alternator ( internal voltage regulated as against external voltage regulated )
blown rectifier plate ( charing with ac current instead of DC)
drive belt tension
best have it checked by an accredited auto electrician
Oct 22, 2015 | Cars & Trucks
Good alternator not charging battery in my 1984 toyota celica gts
How do you know the alternator is good?
You need a digital multimeter to check.
With car off check DC voltage of battery, should be over 12 volts dc.
Start car and measure again.
If alternator is good, dc volts should now be over original reading, if alternator is faulty battery is not charging.
If alternator is good you may have a dead cell in your battery, if so replace.
A give away of a dead cell, is that your original reading of dc volts is under 12V.
May 16, 2014 | 1984 Toyota Celica
UPS battery is over heating while plug in, and this is the regular problem in the UPS battery
The battery in UPS supplies a dc vcoltage to an converter which in turn converts the dc into acceptable ac voltage. When a load is connected to output terminals of UPS, a certain amount of current is drawn which in turn to be supplied by battery to the converter circuit. When the current flows through the battery, due to its own internal resistance heat is generated in battery that causes heating up of battery. When there is no load to ups, but charging of battery is on, the charging current passing througfh the internal resistance of battery heats it up. so either charging or discharging time the battery gets heated up. Ripple is sometime expressed as millivolts to per output volts. insuch cases the ripple has to be multiplied by output voltasge to get the correct value. Ripple content can be measured using fast responding sensors connected to the system or oscilloscopes.
Oct 31, 2011 | APC Smart-UPS SC 1500VA UPS System
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
The laptop doesn't boot. Its dead. I tried connecting the charger, but it doesn't shows any signs of charging. It doesn't even show the laptop is charging.i.e no led is lit when charger is connected.Please...
Hi.
If it is completely dead check the voltage at power adapter DC contacts using a multimeter.
If there is voltage within 0.5 Volts from specifications, then try starting the laptop with no internal battery. A shorted battery may cause the laptop not starting.
If battery and adapter are OK, then the problem is the DC socket in the laptop motherboard. The laptop must be taken apart and the solder joints soldered back. This is a delicate job and must be done by an experienced repairer.
In some case the whole power circuit or the main board may be faulty. Testing is done reading Ohms at DC socket solder joints on main board (or power board, depending on model).
Regards.
Ginko.
Aug 09, 2010 | HP Compaq Presario V5204nr Notebook
My battery is not properly charging..i'm getting
Ck the regulator and make sure battery connections a clean on both ends of both cables. Good luck
May 28, 2010 | 2005 Qianjiang QJ150-C
Garmin GPS 200. Does it work on battery too.
Yes, it has an internal lithium-ion battery that needs to be charged with either a DC car charger or AC wall charger. I do not recommend using the USB cable to PC as a means of charging.
- Jim
Nov 29, 2008 | Garmin GPS
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Battery Will Not Charge
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Mar 29, 2008 | Norcent Technologies DC-420 Digital Camera
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
