Question about Vacuums
How do you clean filter on c88-w2-b
Vax vacuum cleaner model no c88-w2-b
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
VacuumRepair
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
Do you have filterbags for a vax cleaner
Fixya does not sell replacement filter bags for Vax. Check with a vacuum repair shop; they often sell bags.
Aug 10, 2016 | Vax Vacuums
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
How can i unblock my cleaner ?
There may be blockage in the hose or the hose may have collapsed internally.
Oct 23, 2014 | Vax C90-M1-C Mach 1 Complete Multicyclonic...
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintergrating do you think this can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553164
Generic problem for all Vacuums
I was using my vax
Posted by paulxlyn on Apr 28, 2008
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintegrating do you think this can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Apr 28, 2008 | Vacuums
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
I have a Vax Rapide
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
Go Ahead. Use Us.
Vacuums Logo
189 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
