Question about Maytag Washing Machines
How much water should be in drum while washing? WE HAVE A MAYTAG mah6700aww series front load washer. When we first used this Maytag front load washer, we actually had a water line that could be seen through the glass door. Now there is NO water in the bottom of the drum. Our clothes are NOT getting cleaned. Also, there is not enough water that goes through the dispenser to mix with the fabric softener. HELP
    Top Expert:
  • Maytag Master
  • 12,962 Answers
Check the solenoids that admit water into your machine. If they do not open properly when they are energized, you will get little or no water and no cleaning!
Posted on Jul 24, 2017
4 Suggested Answers
  • 3 Answers
SOURCE: lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Posted on Feb 10, 2008
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
  • 79 Answers
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Posted on Feb 08, 2009
Maytag 4000 series 4.5 cu saying SUD PLEASE HELP!!!
this usually means to much soap.you can either shut it off or unplug it for a few minutes let the suds die down and restart it with just plain water this may to a couple of times. you can also use a wet dry shop vac and attach it to the end of the drain hose to remove all the water and restart your machine.
Oct 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
Mar 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer-can't adjust water temp. Smokes.
sadly we make no physical repairs like a repair shop will .
Oct 08, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
