Question about Dryers
I have a Whirlpool dryer model LEN2000JQ0. The heating element glows red and gets really hot. You can feel the heat and smell the heat I go to turn on the dryer it makes a buzzing sound and the drum will not turn I have to open the dryer door to get the buzzing sound to stop but the heat will continue. I have to unplug the dryer to get the heating element to not work. I did turn the dryer to the Air Fluff and it will still be extremely hot air coming out. I have taken apart the dryer cleaned everything out to see if anything was plugged. Cleaned the motor very well. The motor does turn by hand easily. Wondering if it might be the High Limit Thermostat?
  • Diane Lovell Dec 31, 2012
    The drum is not hard to turn by hand either.
  • Dryers Master
  • 8,220 Answers
I would change the control thermostat. It is mounted next to the skinny white fuse on the filter housing under the dust cover on the back side.
I worked on a dryer like this that had a heat problem and wrote about it HERE
Posted on Dec 31, 2012
  • 3 more comments
  • Dan Webster
    Dan Webster Dec 31, 2012
    I would also check for short between each terminal of the heating element to frame. Seen it.
    Would the short cause the heating element to stay on all the time. Even if I have not turned on the dryer. It can be in the off position and the heating element will get real hot. I have to unplug to get it to turn off
  • Dan Webster
    It ain't supposed to be coming on IF the motor ai't running. Your cent switch could be defective. With the power disconnected and the motor unplugged from the harness check between terminal 1 and 2 on each end of the motor connector block. If you get continuity you have a bad motor cent switch.
  • Dan Webster
    The buzzing sound would be the dryer trying to start up on the run windings and not the start windings because that centrifugal switch is stuck in the wrong position. Sometimes you can lube the cent switch and work it by hand till it slides easy but do not use wd 40 or any flamable oil. Use only appliance oil. Zoomspout oil is available at ACE hardware and is safe or dryers.
  • Dan Webster
    When you hit start the motor start winding gets energized when the motor gets up to speed the cent switch job is to allow power to the heater AND to the run windings, the start windings drop out when the motor is at full speed.
Why won't my whirlpool electric dryter #ler4634dqo generate heat?
if you have a old house that has fuses sometimes only half of the fuse will blow making it look like the dryer is working but it wont turn on the heat element take the shielding off the heating element and start the dryer and see if they wires glow red hot when running and also after running the machine does the inside feel warm or cold if it is warm check the duct work on the dryer all the way out to the exit and see if lint is clogging it up
May 05, 2014 | Whirlpool Dryers
What should we do? Our Whirlpool Thin Twin dryer doesn't get hot anymore.
You can fix it,, Here is an easy test and I can give you a definite answer on your problem and solution
open your dryer door, on the door you should see a little peg or clip sticking out which pushes into a corresponding hole in the on the front of the dryer. That's the kill switch for the dryer , it will click when you push it in, hold that in and turn your dryer on its highest setting.
Then look in your dryer while it's running , inside in the back you will see a lot of holes or slats in which the heating element pushes the heat through. You should see a slight glow and feel heat from those holes/vents, if not then I'm saying your element is out. You can normally order one through your local hardware/ appliance store using the dryers model number. For anywhere from ($20-$50)
Apr 29, 2014 | Whirlpool Dryers
Roper Dryer RED4440SQ0 TOO MUCH HEAT
T'he glow you saw was on the back wall in the dryer behind the a grated area if I'm correct. What you saw was the heating element, or a reflection of it while it was on. The element glows bright red when power is being applied to it to function and is housing is made of sheet metal so it does carry a reflective quality. If you really want to make sure that the dryer isn't over heating, which I don't believe it is due to the fact that would mean the high limit thermostat has failed in a way that I've never really seen, take the vent off the back and using a digital thermometer check to see how high it gets before the machine cycles off and the temperature drops.
Jun 20, 2012 | Roper Dryers
I have a Whirlpool dryer model LER4634JQ0. It now takes many cycles to dry the clothers. I checked the vent coming out, it is not clogged. I can reach in and feel a little fan motor, which I assume...
your vent line from the wall to the outside of the house can be clogged
or your you high heat coil is burned out and just the low heat coil is working, when you switch to high, both coils work. or you have a one coil system and the heat selector maybe defective
Please rate/vote the response Thanks
Dec 20, 2010 | Whirlpool Dryers
Dryer runs but doesn't dry clothes.
hi,check to see if element gets hot,run dryer for 5mins. open door and look at back of dryer.you should see a red glow.or you should feel heat.if not the element needs replaced.and make sure the tumble is tumblering. a dryer can sound like its running,but nothing is really happen.
May 29, 2009 | Dryers
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Mar 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
