Computers & Internet Logo
Anonymous Posted on Jan 18, 2009
I have a GE mini mouse model 98796. It worked well but recently it will move the pointer,the left button will not work and the rt button does strange things.
Anonymous
Level 2:
President:
  • Expert 8,637 Answers
  • Posted on Jan 20, 2009
Anonymous
Expert
Level 2:
President:
Answers
8637
Questions
0
Helped
2741004
Points
514
Recommend Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Do I need a receiver plug-in for my Gateway laptop to use a GE wireless optical mouse model 98763?
Garrett, Yes, plug in the receiver that came with mouse. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Wireless Mouse and Driver Problem Fix
http://techin.oureverydaylife.com/ge-wireless-optical-mini-mouse-stepbystep-setup-13706.html
GE 98796 Wireless Optical Mouse Manual
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
GE Wireless Optical Mini Mouse Model 98793 doesn't work properly. Pointer jumps to the right constantly. I use mac, doesn't look like this mouse has any drivers and i also tried pushing both buttons,...
sir
you are thinking right. Its the manufacturing fault . There is no problem with your system.
you should replace this mouse with new one thats all u can do.
thankyou for using fixya
dont forget to rate the solution
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
4helpful
4answers
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
4helpful
2answers
Frozen mouse pointer
I had same problem. While I have only recently "fixed" it, I'm not sure how long-term the solution is, yet. From control panel, double-click mouse, select the "Hardware" tab and choose "Properties" button. Select the "Advanced Settings" tab, and lower the "Sample Rate" to 60 reports/second. Mine was set at 100 r/s. I also increased the input buffer to 120 (having no idea of what a normal buffer size might be). Anyway, on reboot, it worked (which is significant progress, since every reboot before, I had to uninstall drivers, remove mouse cord, scan for changes, plug in mouse, then scan for changes again, /sigh). Good luck.
Top GE Computers & Internet Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
