Question about Balboa Instruments SUV & M-7 Heater Assy. w/Sensors 5.5 kw 58000
Balboa digital 7
Temperature will not change - only 55 degrees no matter what I set the temperature to.
    Genius:
  • 1,669 Answers
Change out the thermostat!
Posted on Dec 31, 2012
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Balboa vs500
Your economy spa is equipped with a hot stick. This "hot stick" is nothing more than a PVC manifold that forces the water through multiple 1/2" ports that creates enough friction for the water to heat itself. YOUR HOT TUB HAS NO HEATER. The benefit is that there is no heating element to corrode and replace. The down side is that it takes quite awhile to heat the water. If you start with water that is 55-60 degrees it will easily take 48 hours to hit 100 degrees. Keep in mind that is dependent on the outside air temperature. Good luck with that!
May 02, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Balboa Hot Tub (topside) control panel.
Hold temperature UP & DOWN together for 6 seconds.
or
Jun 03, 2012 | Balboa Instruments Duplex Digital Panel 2...
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
What is the normal and the lowest temperature that the Haier HNCM035E, 3.5 CU FT capacity C hest Freezer will susstain?
WATH IS THE NORMAL AND LOWEST TEMPERATURE THA THE SMALL MAGIC CHEF FREEZER MODEL CUF3DS
Sep 10, 2009 | Haier Freezers
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Balboa Instruments SUV & M-7 Heater Assy. w/Sensors 5.5 kw 58000 Logo
71 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Mike Raino
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
