SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
SOURCE: my siemens Aquastop will not
Hi.
Check first drain well and drain hose at the back of the machine. Ensure that there is no blockage, remove the well assembly and clean it.
Access the aquastop device located at the bottom of the appliance and empty the container that is part of the device.
If problem comes back check the aquastop that is probably not working properly.
Bosch Dishwasher Pressure Chamber Aquastop
Disconnect machine from power before performing any maintenance.
If you want to call a technician ring the number listed on the owners manual.
SOURCE: Hello, i have a Siemens
It's possible that the Aqua-Stop flood protection system has been activated. I can probably help you, but I really need more information.
1. When you start a wash program, can you hear the pump running? - This will be a low pitch humming sound.
2. There is a dome/mushroom shaped plastic protrusion in the bottom of the washing compartment, located behind and between the salt compartment cap and the drain. Can you lift this up (be gentle) or is it already up and can only be pushed down?
Please post this information and I will try to assist you further.
