York tg8s080b12mp11a blinking red light
Red light blinks 4 times
  • Mike Smyczynski Jan 02, 2013
    This is a York furnace model number, not a projection TV
3 Suggested Answers
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
stonephoenix
  • 563 Answers
SOURCE: Red Light Blinks 4 straight imes
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The 4 red blinks is similar to an error code. It represents what's wrong with the TV to a service tech who knows how to repair it. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need a power supply module. If the problem is one of the video circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
Fix for 4 red blinking lights - standyby
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 21, 2015 | Sony BRAVIA Televison & Video
My York Stellar heat pump runs for some time normally. Then the thermostat light starts blinking 4 times (error code 4). However, the discharge line gets normally hot. It will work ok again for a time...
Your outside unit has a processor with an LED that also blink the error code. Check the ledger on the access panel, instruction sheet or on processor for explanation of the code
Mar 26, 2011 | Coleman Heating & Cooling
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
3red lights how do i find the code
Press and hold the sink button then press the eject button 4 time
and note the 4 digit code .
4 blinking reds = 0 3 blinking Reds = 3 2 blinking reds= 2 1 blinking red=1
The code doesn't relay matter ,the problem is broken solder connections.
under the G.P.U 90% of the time , and that chip need to be re-flowed.
if you have any questions just comment and ill respond.
Rob
Oct 19, 2009 | Microsoft Xbox 360 Console
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Dec 13, 2008 | Panasonic TH-50PX50U/P 50 in. HDTV Plasma...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
