Question about Empire RH35 Mid-Size Heater
I have a DV-35 with optional blower. The blower goes on but does not shut off what should i do
The pliot and burner goes on but it won't shut off when the thermostat is turn to the lowest point
Replace thermostats and or thermostat wiring. Did you wire this your self
May 13, 2016 | Empire DV-35 Heater
When I turn the engine off the blower motor keeps running and will not shut off
Most likely the resistor has shorted to hot. It is close to the blower.
Nov 28, 2015 | 2004 GMC Envoy
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
The blower for AC blows until i put it on 4 then it shuts off.What is wrong?
The blower resistor sounds like it is worn or burnt out. It could be a bad speed selector switch that is easily tested with a volt meter on the resistor connector. And while your there with the meter, leave the resistor unplugged and switch the meter to ohms and test the resistor. A zero reading would indicate if its bad.
And your question on the galant, ES usually stands for what sub-model the vehicle is. Meaning what engine, trans, and options package are available.
Sep 23, 2012 | Cars & Trucks
Our furnace is less than 1 year old - turned it on the other day the the blower does not work ????
Depending on which model optional blower you have, either one requires that the fan switch be turned ON for it to operate (manually or automatically). Also be sure that the blower cord is plugged into a functional* wall outlet. I have included a link to the Owner's Manual for your model Direct Vent Heater. In case you have misplaced yours. Starting on page 18, you will find the 2 optional blower models.Determine which one you have and follow their suggested recommendations, as one requires oiling several times during the heating season.
http://www.empirezoneheat.com/assets//EHS/manuals/12434--0410%20%28EN,FR,SP%29%20DV-%2825,35%29-2SG.pdf
* "Functional" meaning there is power to that outlet and a circuit breaker has not been tripped.
If you continue to have an unsolvable problem contact Empire Comfort Systems Technical Service Dept 800-851-3153. The blower has a I year warranty. If you have your dated Proof of Purchase, repairs or replacement may be covered.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Empire DV-35 Heater
How can i determine if I have a DV-25, or a DV-35 heater and where can I get parts and a blower assembly
There is a data plate on the back of the unit which will have the model and serial numbers on it. Also the -25/-35 most of the time mean the size of the opening/viewable area. You can find parts for it at www.ibuyfireplaceparts.com
Apr 16, 2011 | Heating & Cooling
Hi, I have a empire heater dv-35, I just noticed that the blower motor isn't blowing as hard as normal,could this be I need a new motor?
check for any blockage where the air comes our OR as you said, it could be a dry shaft/bearings and not spinning as fast as it should. are there more than one speed involved? otherwise if poss. try spinning the fan manualy and see if it stops too soon or hard to spin freely...yes? then try spraying oil at the bearing or just replace it. good luck!
Jan 16, 2011 | Empire DV-35 Heater
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
Empire RH35 Mid-Size Heater Logo
42 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
