Vizio Model M220MV. Logo lights up when power button on remote is pushed but there is no audio or video.
Joe fix
  • 7 Answers
SOURCE: vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Posted on Jan 14, 2008
phongnv
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
  • 76 Answers
SOURCE: My Vizio remote doesn't work...
I know that on the Logitech Harmony Remotes, sometimes the infrared LED emitters go bad. Perhaps that is what is happening to your Vizio remote. If everything was working just fine but now none of the buttons work, it is probably your issue. You can test to see if the LED(s) are working by using a digital camera (or cell phone camera). Here is link that describes how to test to see if your IR emitters are working. Although you have a different model, you may be able to pick up a few tips from this article. Good luck!
http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
Posted on Mar 02, 2010
SOURCE: vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
Posted on Mar 21, 2010
ginko
  • 19396 Answers
SOURCE: VIZIO GV42LHDTV Got TV after
Hi.
If the TV does not start with the new audio board, and if it does start with the old one, then the audio board that you recently purchased is defective.
About the board : 0500-0507-0230; that is the power board (PSU). If you could see the Vizio logo, that means that TV started, and that the power board was OK without need for testing. When the power board is defective, either the TV does not give any sign of life, or the TV goes in standby mode from start and does not wake up. In that case the led stays blinking to warn you that there is an incorrect voltage from PSU.
If the TV is freezing with Vizio logo, that means that at most the faulty part is the main board.
Also, you say that there is no backlight. No backlight means that the screen is completely dark. If there is no backlight you won't be able to see the logo or any other picture.If there is no backlight, then the problem is usually the inverter.
Here a brief article summarizing how to test PSU and inverter: How to test an LCD TV.
Here all parts for this model:GV42LHDTV.
Regard.
Ginko.
Posted on Feb 11, 2011
Vizio model M320SR has black screen but has sound. V logo appears when tv is first turned on then goes away.
If there is no video but you have audio or you have intermittent video:
  1. Press and hold the mute button on the VIZIO remote for 3 to 5 seconds. Some VIZIO TV's have a "Mute Screen" feature that turns the screen off if you are streaming an audio application (Pandora, Spotify, etc) and don't want the screen on. To activate/deactivate this feature, hold the mute button for 3-5 seconds.
  2. Turn the TV off and unplug it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
  3. Check the connections between the TV and device. Ensure the cord is connected securely to the TV and the source device.
  4. Try a second device. (Example: If the issue happens on a Cable/Satellite box, try using a DVD player or gaming system to see if the issue occurs there.)
    1. If the issue occurs on multiple devices there is an issue with your TV. Please contact Support by Clicking Contact at the bottom of the page or give us a call Monday - Friday from 7am - 11pm Central Time or Sat. & Sun. from 9am to 6pm Central Time at 855-833-3221.
    2. If the issue only occurs on one device the issue is not with the TV but with the device or the cables used to connect it to the TV.
Jan 26, 2017 | Vizio Televison & Video
TV has no picture, no sound just the VIZIO logo light is on the screen.
Did you check out the power supply for proper operation since both the audio and video are gone? If PS is good then the problem may very well be on main board.
May 03, 2016 | Vizio E421VA 42 in. LCD TV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
Vizio 55" smart tv e552vle no power or standby light!
Have you tried un plugging the TV for 10 minutes and seeing if that clears the lock up? This is a software issue I'm sure.
Mar 23, 2017 | Vizio L32 32 in. LCD HDTV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
On and off display is blinking
Someone needs to open it and check first the voltages in and out of the power supply board.
Mar 16, 2012 | Vizio M220MV 22 in. HD-Ready LCD TV
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
