Question about Hitachi 50FX18B/19K 50" Rear Projection Television
Spiderwebs under Screen, how do i clean it ?
Got this tv in 96, everythings fine except theres some spider webs behind the screen plastic that you can see but cant get at. how do i take the screen off to clean this ? thank you :D Josh
  • 398 Answers
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Posted on Jun 26, 2007
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Take off screen on hdtv misubishi 62628. the screen has a spider web behind it and i want to clean it out
To remove the spiderwebs, you don't need to take the whole thing off. You just need to remove the screws around the screen frame (top and sides). The screen frame and mirror cover can be separated several inches with ease. You just need to use a flexible duster, one of those electro-static attracting numbers would be great, to clean the web out. Be careful not to disrupt the rear, large mirror and don't scratch the screen. Good luck.
Mar 15, 2010 | Mitsubishi WD62628 62" Projection HDTV
How to clean the screen
Start by taking off the front bottom cover, usually they have screws way at the bottom one on each corner, then uncrew the screen usually there is 3 screws at bottom of screen pull up and out on the screen the screen has small screws in the inside all the way around take them off once you reached screen take it out and split it in half clean it with dry rag then put everything back together exactly the way u took it off before you screw the screen back clean the projectors with dry rag and the mirror with windex or any glass cleaning product.
Jan 31, 2010 | RCA P46812BL 46" Rear Projection...
I have a spider web behind the screen, how do i
sometimes on sony TV's on the sides you will have a door, that you can open with a screwdriver. if yours have it you might be able to dlean all that web from both sides, if not its a little bit more complex.
Jun 25, 2009 | Sony KP-53HS30 53" Rear Projection...
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Spider on screen
You must remove the top back cover, but be careful and handle it gently because the mirror is attached to the inside of that cover. When the cover is removed you will be able to clear out any spiders, spiderwebs and dust and be sure to clean the 3 lenses on top of the 3 picture tubes.
Aug 09, 2007 | RCA P52926 52" Rear Projection Television
Phillips hd 55 inch
It could be either place probably on the back of the screen itself. If it were on the picture tubes it would be big. You'll have to take the back off and check it. Stargazer
Apr 19, 2007 | Philips 36PT842H 36" TV
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
