Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Code 7 on coleman furnace
What are the possible causes for no ignition?
  • Ken Bledsoe May 11, 2010
    Faulty ignitor
    Faulty circuit board
    Faulty pressure switch
    Faulty Gas valve
    Faulty Thermostat
    Faulty transformer
    you get the idea there are a few things that can cause the problem. As the process of lighting the burners have to be satisfied for a safe ignition.
  • Perry Putnam
    Perry Putnam May 11, 2010
    what kind of igniter? Hot surface(glow coil) or spark? Explain step by step what it does.
    Guru:
  • 462 Answers
Dont forget faulty ground too. But by now I bet hes got this going.
Posted on Mar 30, 2009
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a coleman evcon gas furnace that keeps giving me an error code (Limit switch open, and sometimes it wont kick on when i get this code, I have replaced the Lower Limit Switch, and workd fine for a...
i hope the heater doesnt come on when a limit switch is open,you really have problems. so a limit is telling you that your furnace it over heating. first check filter and heat vents and returns they must be clean and open. closing heat vent or blocked returns will cause over heating. after chacking this look at firing rate. furnace could be overfired. you would need a "u" gauge to check manifold pressure. your name plate will tell you what this should be. find the tap on the burner manifold or outlet of gas valve. fire furnace and see what it is. 3.5"wc for nat and 10" wc for propane maybe.
Feb 10, 2011 | Coleman Propane Forced Air Heater...
My coleman furnace lights and then when the fan kicks in the flame goes out and i get a trouble code of ignition what could cause this
HI 2 things try jumping out the pressues switch see if it lights check out the hotsurface ignitor seeif it glowing or cracked and check the flame sensor is clean
Jan 24, 2010 | Tools & Hardware - Others
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
91 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
