I have a MPI 41 monitor heater. k-1. runs for a bit and shuts down..88:88 appears as well as the orange indicators do. they flash together. any suggestions. I also had a repair man here twice and still doing the same thing.
  • john kresge Dec 31, 2012
    like I said, still not sure if I'm doing this right. sorry. but the answer to the questions is a bit 1-4 hours. the clock, I didn't see him disconnect it.I don't use the clock at all.Should I? I don't believe it has a battery back up.it was manufacturer in 1992 and no child safety lock.
    Problem Solver:
  • 16 Answers
How long is a bit?
Sounds like the clock is faulty - Did the repair man disconnect it from the mains? (Turn it off and on again! ;)
Does the clock have battery backup?
Is the mains power steady?
Is the time set correctly?
Does your unit have child lock?
Posted on Dec 31, 2012
    I don't know if you received the answer to your questions or not.
3 Suggested Answers
SOURCE: monitor 41 oil heater stove lost its heat...
We repair Monitor Heater main circuit board and push button panel. call me at 800-782-4449 ask for Dima
Posted on May 07, 2009
  • 674 Answers
SOURCE: my mpi 41 moniter heater
Do you see any flames before the heater cuts off? If not, check the igniter first. You can check it with an ohmmeter or with a clamp on ammeter. If using an ohmmeter, the igniter resistance should be between 10 - 20 ohms. If using a clamp-on ammeter, clip around just 1 igniter lead and you should get 2 -4 amps.
Does the fuel pump start making a thumping noise before the heater cuts off? It makes this sound when it isn't getting any fuel to it. Check your fuel filter and fuel strainer. Be sure to shut off the kerosene before checking either.
If you do see flames before it cuts off, you need to check the flame rod. Clean it with some steelwool or emory cloth. The flame rod is located next to the window on the combustion chamber and has 1 wire going to it. Unplug the heater before checking.
If this doesn't help, let me know what you have found and I can give you more info.
Posted on Jan 05, 2011
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
E-14 code mpi monitor 2400
It sounds like you have a fuel problem, check to see if there is some kind of blockage in the line or at the tank value.
Jan 25, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
My mpi 41 moniter heater will come on for a few minutes and then shuts off and the display window flashes 88:88 plz help!
Jan 05, 2011 | Heating & Cooling
Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches...
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Dec 31, 2010 | Heating & Cooling
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
Monitor 41 oil heater stove lost its heat...
Feb 01, 2009 | Heating & Cooling
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
581 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
