Question about Samsung Televison & Video
PN50B550T2FXZA won't power up
Red light stays on, you can hear a clicking noise, and nothing happens. The red light doesn't flash, the TV just doesn't power up.
    Top Expert:
  • Samsung Master
  • 37,841 Answers
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Posted on Dec 31, 2012
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
localwonder
  • 6784 Answers
SOURCE: Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Posted on Apr 13, 2009
  • 1039 Answers
SOURCE: My tv won't turn on. There is a red light
Replaced any capacitors on the power board that have domed tops.
Posted on Sep 01, 2011
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
  • 90 Answers
SOURCE: RED FLASHING LIGHT TV BLACK
does the television stay on ? these codes or flashing lights and designed to tell you about a problem that the internal computer had detected - a single flash then a double flash is a software upgrade notification -- call support at customer service and they will tell you exactly what the flash is related to then you can find the fix or repair with more information
Posted on Feb 24, 2009
Won't power on
Sounds like a Zenith or LG TV. It is most probably the Y board, when you hear the clicking sound is usually that. I am sharing this with you because it happened to me with a Zenith (POS). The red light (on my TV) is in the bottom right corner. In my case it was the Y Board. Best of luck
May 14, 2017 | LG 50PA4500 50" 4500 Series Plasma HDTV
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
My dynes 40" Dx-L40-10A doesn't turn on. I hear a click but the light will stay red and nothing appears on tv. Occasionally, if i unplug the tv for a few hours i can get it to turn on.
just let me know first if you will be the one to the repair since it needs a proper trouble shooting. a voltage checking and a component parts checking. the cause of the this kind of trouble is either a power supply board failure or a bad component in the main board. so isolate the main cause you will need to have trouble shooting and right device and tools.
Nov 07, 2012 | Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have an lg plasmas model # 42pc5d-uc the tv is not turning on. When I push the power button the red light flashes a few times I hear a click & nothing happens it goes back to a solid red light...
All put the name in with the model. Its a LG .Your power supply is down. This could be capitator or transitor bad if the caps are swelled up replace them with the same value .
Mar 01, 2011 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
556 people viewed this question
Henry  Thomas
Henry Thomas
