Good day, my peugeot 206 1999 runs on first start of the day erratic and stops, when start again it runs ok, when engine is warm it starts ok but runs at high idle +/- 2500 rpm to 3000 rpm. it's not the throttle that is sticking and iv'e changed the idle stepper motor. what can be making it idle high?
SOURCE: peugeot 206 glowplugs
If your not good at mechanicing I suggest you take the car to someone that is experenced.
The reason I say this that we have loads of cars into the workshop with glowpugs broken in the head of the engine with the result of us having to remove the cylinder head.
What happens is that the tip of the glowplug breaks in the head when being removed if it is not done properly.
There is a way that we have found that they can be removed easily without breaking them.
Firsty run the car engine until warm, then we pour a little Diesel fuel onto each plug & let them sit for 15mins or so.
Then we remove them with a deep socket 1/4" drive so we don't put to much pressure on them.
they should screw out easily but we turn them out 1 whole turn then back a 1/4 add a little more diesel ( thimble full) & gently screw them out.
If they start to get really tight screw in again a little then screw out again.
The nuts that hold on the wires just need to be nipped up with a small 8mm spanner, but do not over tighten.
SOURCE: Peugeot 206 starter motor not turning
put your voltmeter on the little cable that goes to the starter and check the volts there will turning the key to the start position if you have power ...yes its the starter...if you dont then it could be the starter relay
SOURCE: Hi, peugeot 206 clutch/engine problem..
It seems like the clutch pressure plate has given in. Best would be to replace the clutch pro-kit.( Clutch pressure plate, clutch plate and release bearing)
Testimonial: "A mechanic said basically the same to me today, so I'll be getting it replaced. Nice one knight :)"
SOURCE: p1613 fault code & engine will not rev over
Crank sensor or engine speed sensor is faulty.
Fault:
Irregular power loss on accelerating
The speed of the engine is limited till 2500rpm
Frequent loss of crankshaft position sensor signal
Cause:
It is caused due to leaking from thermostat housing into crankshaft position sensor harness multi-plug
Remedy:
Check and clean the crankshaft position sensor harness multi-plug contacts. Rectify the engine coolant leak from the thermostat housing if found. Take a note of the engine coolant level and monitor it for changes, showing a leak is indeed occurring.
SOURCE: peugeot 206 1.4lx misfiring engine light flashing
Probably a defect lambdasonde or inlet pressure sensor (MAP sensor) it will show many different errors on the test readout ex: inlet manifold pressure, knock sensor, lambda value wrong, idle speed out of range, etc.
read out the faults,after delete the readout, then drive one day, read faults out again , compare the results, and change the components from test
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
are many other possibilities causing these idle issues.Engine idles rough.
There
I
Click
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at
idle after engine rebuild?
1999 Ford F-150 Idles rough and quits when gas
pedal is pressed less?
Engine stumbles coming off idle when warm?
Erratic idle on car?
3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
GMC Sonoma Stalls and idles low
GMC Idle Air Control (IAC)
Valve Replacing?
1996 Camry intermittent
engine failure while idle?
Engine quits at idle?
Car overheats and Air blows
hot at idle?
High
Idle Problem
While stop engine idles
like cylinder missing?
Idle flair is noticed on car? Rough idle? car
will not idle? Erratic idle speed?
High rpm in neutral? Inconsistant high RPM in
neutral?
Vehicle stumbling at idle
and shows code 54?
Rough idle, staling and Erratic shifting?
These
details will help.
Thanks.
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?
http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
3500 rpms
High rpm in neutral? Inconsistant high RPM in neutral?
Jetski
Sputters and Low RPM?
http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel
Injection Problem And RPM suddenly increases
http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM
below 3000?
http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?
http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise
Control stops working, Excessive cranks to start the engine and RPM goes max
2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when
reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high
engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?
http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
