Question about HP Touchsmart AY581AA 300-1120 All-in-One Desktop PC - Dual-Core AMD A
How to replies CMOS battery in Touchsmart 300-1120
Can someonehelp me to changing CMOS battery in my Touchsmart 300-1120? i've a problem with date and time are always reset after sshutdown
    Sergeant:
  • 378 Answers
Http://produtools.com/d/manuals.php
please take timne to rate if this helps you
Posted on Feb 01, 2013
How to change the cmos battery on a touchsmart 310 1020
  • Study the Upgrade guide from HP before starting so you can remove the battery if you drop it in the machine by accident. As of the time of writing, there is no dedicated guide on how to change this battery the long way. Because of this I am going to recommend reading the HP upgrade manual for now. Once you have the back removed, remove the screws from the motherboard EMI shield. These are all the same length, and can be sorted in one pile. Find the battery and remove it from the system once you find it.
  • You should ideally use ESD safe tweezers for this procedure. You are after all, poking around at the system's internals semi blindly. It doesn't hurt to be sure.
  • Jul 19, 2016 | HP TouchSmart 310-1020 All-in-One Desktop...
    Change cmos battery hp touchsmart
    https://www.youtube.com/watch?v=ps76kz63Tjw
    at about the 10 minute mark when the cover is removed, you will see the cmos battery to the left of the plug in memory modules
    Hope this helps
    Mar 07, 2014 | HEWLETT-PACKARD Hewlett Packard TouchSmart...
    Lost password...No help on internet so far for this model
    There's only two ways to reset the CMOS battery on this laptop.One is to short out two solder points on the motherboard, which works on this model, as per this guide:
    http://findpassword.net/reset-toshiba-satellite-bios-password/
    The other is to contact Toshiba for support. They'll be able to help so long as you can prove ownership.
    Oct 21, 2012 | Toshiba Satellite L15-S104 Notebook
    I replaced the cmos battery and cleared it
    You cleared your cmos while windows was installed. NEVER reset, clear or load default w/o backing up your system before. You changed something in the bios that is no more according with the windows configuration. Good to find what. Try to reconfigure your bios maybe it will solve your problem. But if not you've to reinstall windows.
    Aug 05, 2012 | Dell Dimension 8400 PC Desktop
    P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
    If your cmos battery is new and the date and time not change. Try the following.
    1. Clean the cmos battery terminals.
    2. Check your mother board if there is bulges capacitor.
    3. Check the memory you have using if in the same voltage requirements.
    Hope this will help to you.
    Jun 15, 2012 | ASUS P4P800-VM Motherboard
    No Nvram Found
    NVRAM should be your BIOS, if that's not found you've got something wrong with your motherboard. I don't think it's a dead CMOS battery but you could try changing it, dead CMOS batteries usually say bad checksum.
    edit: try removing any hardware you don't need for the computer to boot then if it works, add them back one by one __________________
    Apr 05, 2012 | Dell 5210n Laser Printer
    HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
    Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
    Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
    How do i change the cmos battery on my sony vaio vgn-fs750p?
    g'day!
    get a new battery -usually the CMOS battery type is 2032- from an computer, electronic or a watch shop.
    power down your pc.
    remove the cover. make sure you are grounded when touching the motherboard to protect it from ESD.
    remove the battery and install the new one put it (+) side up.
    once you've changed the battery. close it and power up the battery.
    go to the BIOS of the computer and change the time and date as well as the settings.
    cheers mate.
    jelo a.
    Aug 20, 2011 | Computers & Internet
    I've changed the CMOS battery of my GX260 series desktop as it was prompting an alert as "System battery voltage low" & after that Systems IDE configuration failed performing an automatic...
    Press f2 to enter the BIOS while you see the Dell start up screen. Once in there you shoudl see an option to load BIOS defaults. Load defaults. This should take care of the issue. Are you sure that you replaced it with an approved CMOS batter, You cannot use a watch battery, even though they are the same size it won't work.
    Aug 01, 2011 | Dell OptiPlex GX260 PC Desktop
    Good Morning Sir... My Mother Board Is DG41 WV In This System Problm Is Cheq CMOS Problem... So Iam Change The CMOS Battery... Again Smae Problem Phase... & CLR Cmos Jumper Changed Again Same...
    If you've replaced the CMOS battery, set the date and time as well.
    If the CMOS setting default to the very first date (1st January 20??), it'll automatically report the "Check CMOS" error.
    Let us know if this works,
    -BuzzPuppy
    May 01, 2011 | Computers & Internet
    HP Touchsmart AY581AA 300-1120 All-in-One Desktop PC - Dual-Core AMD A Logo
    574 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
