Question about Nordic Track AC Adapter for C2 SI, C3 SI, C4 SI & GX2 Bikes
Continuous beeping, not low battery as it occurs while plugged in via AC adapter as well.
  • app_3rp89293
    app_3rp89293 Dec 31, 2012
    Sorry, this should not have been posted under the AC adapter product. The problem I'm having is with the NordicTrack C2 SI console, not the AC adapter
I have a 19.5v sony AC adapter that wont charge my laptop and it keeps beeping when its plugged in how do i fix this?
is the ac adapter the one that come with this laptop?
it might be the ac adapter has got a fault with it.
take the battery out of the laptop and then plug your ac adapter in and see if you can switch your laptop on.
if it does come on with the battery out then it might be the battery thats at fault.
Dec 17, 2016 | Sony Computers & Internet
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
The ac adapter for my Acer laptop has a continual beep in it and is no longer charging the battery.
Remove the laptop battery / plug in to mains, if beeping has stopped, faulty battery. If not then charger or mains faulty.
Feb 08, 2010 | Acer Aspire 6920 Notebook PC
No power
It the notification occurred while the AC adapter was connected to the system, then I'd suspect the AC adapter 1st.
If available, try another compatible ac adapter and see if the system powers on.
Since the system will not power on with AC adapter alone, I suspect it has failed.
Places Like Best Buy, should have a bench AC adapter you could test to see if the system powers on, if so, then buy a replacement.
If under warranty, contact HP tech support.
Jun 15, 2008 | HP Compaq Presario C304NR Notebook
Nordic Track AC Adapter for C2 SI, C3 SI, C4 SI & GX2 Bikes Logo
74 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
