Question about Kenmore 64952 Electric Dryer
Addendum to original problem
Have a Kenmore Elite 649723 Electric Dryer. It runs fine in both timed and autodry modes with no heat (Air Fluff). However, when using heat, the unit stops after 20-30 seconds in all modes. At first it seems like the heating element is overheating and kicking off but that seems weird since I can restart the unit immediately and it will run for another 20-30 seconds. Comment by rbflapjack, posted on Jun 24, 2007 Believe it or not, the problem changed to the start button issue. I was taking off the vent line to make sure it wasn't clogged. I had to move the dryer out a little bit. After disconnecting the vent line, I started the dryer in Air Fluff and it ran fine. I then switched to Normal heat and the dryer stopped. Now it will only run while I depress the start button. Maybe it is this even heat board thing? If so, how do I check it and/or replace it? Thanks
  • Robert Pfannkuch Jun 28, 2007
    I replaced both the even heat board and the thermistor and everything seems to be working great. Great Solution! Thanks!
    President:
  • 878 Answers
Rbf, the even heat board sits under the consol next to the timer. You could have a dual problem here. On your first post you said the dryer would run for approx 20 to 30 seconds and then shut off. This is a sure sign of a failed thermistor. You want to check it out. If you have to hold the start button in, then I would suspect the even heat board. I have seen this many times. Flip the consol up and inspect it. You will have to slide a putty knife under each end of the consol. You will feel a clip. Push on it and pull up at the same time. The consol will lift up. See if you see any burn marks on the board. Sometimes they look good but are bad. The part number for the board is 8545904. Double check that but Im sure it's right. With out being there and from what you are describing, I would go for the even heat board. But I would also check out the thermistor. Catriver.
Posted on Jun 24, 2007
SOURCE:
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smartheat quitpak electric dyer
Hello talee725. the dryer has heat sensors located throughout. One at the air intake & exchaust of the heating element including the air exchaust of the drum. Disconnect the AC power, close the gas valve is gas powered, clean them and check the sensors with a DVM in the ohm scale for open ckt. They are usely round in shape with 2 wires connected. If test open call a local appliance parts/repair center for price and stock.
Nov 05, 2008 | Kenmore Elite HE4 Electric Dryer
Stops after 20-30 seconds but only when using heat. Can immediately restart.
rbf, in looking Im not finding a 649732, but I do find a 649723. This dryer has a even heat board but also a thermistor. If you had to hold the start button for it to run, I would suspect the even heat board. That's not the case so Im suspecting a open or shorted thermistor. If you remove the lower panel it sits right behind the blower housing next to the thermal fuse. Should be black in color. Part number 3976615. The thermistor should ohm out at about 10k ohms plus or minus 3. When one of these thermistors fails usually you get the symtom your describing. Catriver.
Jun 23, 2007 | Kenmore 64952 Electric Dryer
Kenmore 64952 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
