Question about Roland Spd-S Sampling Percussion Pad System
Replacing sensors on a PAD-80
I have sometimes answers (work/ not work) from three out of eight sensors on my Roland PAD-80. I opened the casing and when I triggered them from the backside, all are working! It seems to have also two extra sensors inside, connected, but when I triggered these, nothing occurs.I wanna know how to remove the pads and if I can use the two spare sensors to replace the faulty ones. Thanks!
2 Suggested Answers
  • 8 Answers
SOURCE: Bought used Roland SPD-11 with
Manuals are here in PDF:
ftp://ftp.roland.co.uk/productsupport/Manuals/
Posted on Dec 31, 2008
Having a problem with the touch screen with my Roland E80 keyboard work station. Very slow or no change . Please help .
Open up the Roland E-80 and check if all connectors and flatcables are well seated.
Dec 21, 2016 | Roland Music
Jeep liberty codes
Possible causes
- Warm Up Three Way Catalytic converter deterioration or malfunction
- Exhaust system leaks
- Loose front or rear HO2Ss
- Faulty front heater O2 sensor
- O2 sensors harness is open or shorted
- O2 sensors poor electrical connection
Tech notes
As the code description implies the P0422 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem. If the P0422 code is combined with other codes, try fixing the other codes first.
Jul 01, 2014 | 2003 Jeep Liberty
P0421 CODES AND C1201
C1201 error code means that you have some problem in engine control system.
Possible causes for P0421 error
  • Warm Up Three Way Catalytic converter deterioration or malfunction
  • Exhaust system leaks
  • Loose front or rear HO2Ss
  • Faulty front heater O2 sensor
  • O2 sensors harness is open or shorted
  • O2 sensors poor electrical connection
The P0421 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem.
Apr 24, 2014 | Toyota Avensis Cars & Trucks
Roland pad 80 is it normal for the lcd display to show a bar of squares and nothing else when pluged in to power and not pluged into anything else?
The Roland Pad 80 has a contrast control, if it's not correctly adjusted, it could cause it to appear all black or all blank.
If the LCD were bad, it's uncommon for both sections to both go out around the same time, since it uses two seperate 7 segment LCD components. About the only way to cause both to go out at about the same time, would be to get the equipment wet, or let it get way too hot or left sitting out in the sun, long enough to dry up the "liquid" part of "Liquid chrystal display".
Oct 15, 2013 | Music
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
The display of my roland XP-80 is Zero, & theres no pragrams or voices, patches display... & the worst is there`s no sound because there is none in the display Pls. kindly give me an advise thank...
The procedure at this link shows you a battery replacement procedure that should work for you:http://ztup.com/Roland-D110-Battery-Replacement-Guide.htm You will need to design new user patches if you didn't back them up.
Jul 06, 2010 | Electric Music
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
Blinking airbag light
The blink code you are refering to is : Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open , which means your right hand side frontal crash sensor (airbag sensor) is not working, therefore your airbag system is disabled...
May 08, 2009 | 2005 Ford Freestar
Roland Spd-S Sampling Percussion Pad System Logo
79 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
