Question about Nintendo Super NES Console
Snes no sound
No sound
  • Nintendo Master
  • 424 Answers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Posted on Jan 09, 2013
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
FC twin will not play SNES games. produces sound only
Try cleaning the cartridges, DON'T USE RUBBING ALCOHOL!!!!!! This can ruin the cartridge, there is a cleaner that you used to be able to buy (haven't look for one in a while). Check with your local game store or on ebay.
Mar 05, 2010 | YOBO Fc Twin Console
Problems with the gray box on my SNES
Well to fix the gray bock you would need to by a broken SNES console off of ebay to find the needed part if you find a broken SNES console with a working motherbaord you might be able to swap the parts then. And will need a bypass plug from radio shack to hook it al toghter then. Its not an easy task and has an 8 out of 10 chance of not working if you don't know what your doing then and a 4.5mm tool bit to open up the SNES too.
Jul 31, 2009 | Nintendo Super NES Console
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
SNES works but no color.
Sounds like your AV Multi-out port circuitry is shot. Yest it with an RF adapter, and if it works perfect with an RF adapter, that is the source of your troubles. I'm afraid that the cheapest solution is to buy a SNES motherboard (about $20.00), which is a lot cheaper than a repair shop soldering in new components to fix it. It's not something you can do on your own.. Google SNES Motherboards type 1 or 2
Apr 08, 2009 | Nintendo Super NES Console
Vertical lines show up on my SNES picture of any game.
Do you have a third party AC adapter for it? If you aren't using the original one, check its voltage. Mine was a 9V instead of a 10V and while it allowed the machine to run, I got visual distortion effects similar to what you describe. If it isn't a 10V adapter, go to Amazon and get a real one instead of a cheap third party one. I got this one (http://www.amazon.com/gp/product/B00009ZKWC) and it works great!
Mar 16, 2009 | Nintendo Super NES Console
Denon 3808ci won't upconvert old video game consoles
Since the games are so old and the SNES is an ancient console most tv's are made for the newer ones/Wii, Xbox, ETc./ So The Tv May Require Certain Wires for the console to function correctly, it also may be that your wires for the SNES are corroding in side *( Copper Wires Etc. )
Dec 12, 2007 | Denon AVR 3808Ci Receiver
Snes
I would suggest that you make sure the RCA jacks are hook up properly, and on the right color.If that doesn't fix it, then its an inside problem.It might need some cleaning.
Oct 05, 2007 | Nintendo NES Console
Nintendo Super NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
