Question about Measuring Tools & Sensors
No signal Unit displays "No Signal"
    Genius:
  • 1,669 Answers
Check the batteries, antenna and location of the base station in relationship to the sensors. Check each sensor's batteries and locations (not near large metal objects and high enough to send signals. Move the base station close to a window facing the remotes...
Posted on Dec 31, 2012
Y, pb, pr no signal
you need to be sure the computer resolution is 1024 x 768 be sure the projector is set to rgb or vga input signal type.
Dec 21, 2012 | Sharp Notevision Pg-m10s Dlp Projector...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I have a Philips LCD 1080P 55" TV and it is showing a black screen with "Please change computer's screen resolution" on the bottom. I don't have a computer linked to this TV...
It does not matter that you do not have a computer hooked up or not what it is telling you in a scripted message where a computer might be used for that connection is that you have a setting wrong in the display section of the flat panel that is not compatible with the input signal. Find out what kind of input signal; you are supplying to the display and then set your display setting if they go that high to that display mode and the unit should give you a picture.
Aug 10, 2012 | Philips Televison & Video
"NO SIGNAL "is displayed on a blue screen
You have selected an input on the display that is not getting any signal that the display can recognize. Press the source button either on the set or on the remote until you get a signal.
Aug 09, 2012 | Element Electronics FLX-1910 19 in. LCD...
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
No signal
  1. Get a clear view of the sky and then turn off the unit and then power on again.
  2. Once the unit is on and you see the street display tap on the signal icon on the screen.
  3. You will see a half globe with horizontal signal color orange and wait for at least 5 full green signal and then close that page.
  4. Once your in the sreet display you will see tsignal strength on the screen.
Feb 12, 2010 | Tomtom ONE GPS Receiver
Can not find signal
  4. Once your in the street display you will see signal strength on the screen.
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Measuring Tools & Sensors Logo
194 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
