Question about Refrigerators
Amana HUM-FP Home Humididfier installation does not look correct. Water enters the unit from the bottom instead of the top. Cannot find installation instructions to verify
The Humidifier water line enters the bottom of the humidifier, which doesn't make sense. The humidifier does not seem to be functioning in this cold weather. The humidstat is set to high for 20 degree fahrenheit. Currnet ambinet temperature is around 25-35 at night.
Joe_Rex
  • 114 Answers
SOURCE: Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Posted on Apr 28, 2007
ScottSwan
  • 33 Answers
SOURCE: Bionaire BCM645 Cool Mist Humidifier leaking water
Same here
Posted on Feb 16, 2008
ginko
  • 19396 Answers
SOURCE: I have an Amana(BB120) refer
There may be different causes when the freezer is not reaching to the low themperature it should get to.
Check that the doors are closing properly and the gaskets are ok.
A common cause can be related to evaporator coil problems. Check that the fan is working and that the the coil is not iced up.
Leave the fridge off , and with door opened for over 24 hours, until you defrost ice condensed on the evaporator coil.
After this the fridge should cool up properly , at least first few days. Check also: Cleaning the condenser coils
Check that the evaporator fan is working , if it is not you will need to check the voltage coming to the fan , and eventually replace the part. Check here :
  • Some help for an Amana refrigerator fan motor that will not run
  • Being the fridge quite old it is also possible that you need to take out gas weigh and recharge it, this may resolve problem.
    If at this point it still does not cool properly you will need to identify the fault testing parts eventually involved. It'may be a open circuit heater or fuse, or a faulty defrost thermistor on the freezer evaporator or a faulty control board.
    Start checking fan and coil and doing a two-days defrost, if this does not work recharge gas.
    Regards
    Posted on Apr 08, 2008
    rickzilla
    • 706 Answers
    SOURCE: Water dispenser frozen?
    I'll take a stab at helping you.
    Most, if not all freezers have a small heater element that keeps the water inlet to that freezer compartment from freezing and if that's defective ( or unplugged ) then any incoming water would freeze before being dispensed or fed into an auto ice maker tray.
    The freezer compartment being 'too cold' should not effect water flow if that heater was operational, however it may allow too much cold air to pass into the refridgerator area causing some food to freeze.
    It's a good idea to keep the coils clean and dust free as a general rule of thumb but those are used as part of the cooling system to draw heat out of the freezer/fridge area but that doesn't seem to be your problem. Hope my comments help !
    Posted on Aug 06, 2008
    aborcass
    • 2651 Answers
    SOURCE: Amana DBR 2201 CW fridge, freezer good fridge not cooling
    sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
    Posted on Nov 30, 2008
    Upper unit freezes up even tho both top and bottom are turned down. only does it occasionally
    Its the defrost problem. The drain hole is clogged and water freezes in the unit instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/amana-abb1927de-bottom-freezer-upper.html --------- This should help.Thanks.Helpmech.
    Jul 08, 2011 | Amana ABB1927DE Bottom Freezer...
    Ice maker installation
    do you have a water supply line connected to the refrigerator? if so, it connects to the water solenoid, so you wont need to install that. if you have no water line, not only do you need to install that, but you will also have to check to see if you also need to install the solenoid assembly. if no solenoid is present, you will likely also have to run a plastic water line, ¼", from the solenoid up the back wall into the sleeve near the top of the back wall, which feeds the water into the freezer, into the icemaker.
    if you want to send a check, id be glad to post a video
    Mar 01, 2010 | Amana ABB1927DE Bottom Freezer...
    Amana arb2257csl waterdispencer not working makes hum but no HTO
    the water resevour is frozen . take and heat up the tubing until the water flows thru.
    Jan 21, 2009 | Amana ARB2257CSL Bottom Freezer...
    Unit Won't Cool Or Heat Just Blows Air and Displays FP
    fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
    Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
    Amana 18 Top freezer Refrigerator-leaking water in refrigerator
    the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
    Jan 11, 2009 | Amana ATB1832AR Top Freezer Refrigerator
    Leaking water
    you need to remove the bottom drawer and check your drain in the back each time it goes into defrost it sounds like the water is running to the bottom of the unit instead of down the drain
    May 19, 2008 | Amana Refrigerators
    Washing machine no cold water
    chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
    Feb 07, 2007 | Amana ALW880WH Top Load Washer
    Refrigerators Logo
    37 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
