Question about AEG Lavamat 72640 Front Load Washer
Machine stops after 5 minutes and shows E10 fault code
Washing machine is a AEG LAVAMAT 72630 It always stops at same point in programme - after 5 mins - is it a programmer fault?
3 Suggested Answers
SOURCE: Only 1 programme working
I Have a Lava mat 72600 and it came up with E9 as this is not in the
manual what should I be looking for? The machine gets redy to let the water in and it just makes a click is the solonoid Jammed or somthing else thios sems a comon prob as it is a question asked elsewhere.
Also how do you get the top off with out breaking somthing?
Posted on Aug 14, 2009
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
E1O DISPLAYED
The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
Peter Kay
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Aeg Lavamat 64840 programme stops at 1 minute to go. turning the machine off doesn't help and you can't open the door
Jul 10, 2010 | AEG Washing Machines
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Aug 06, 2009 | AEG Washing Machines
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
57 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
