Question about Canon PIXMA MP810 All-In-One InkJet Printer
Service error 6800 canon pixma - Canon PIXMA MP810 All-In-One InkJet Printer
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
Posted on Jan 18, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
SOURCE: service error 5100 on canon pixma mp130
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Posted on Jan 03, 2009
  • 92 Answers
SOURCE: Canon PIXMA iP90v Service error 5100
Error 5100 is mostly because of some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.
There is the purge cap (the white sliding mechanism that the print head parks to when it's not in use) which was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display)
Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
What is 6801 error?
6800/6801/P09 - Orange and green light blinking 9 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
From: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#6800
Feb 16, 2016 | Canon PIXMA Office Equipment & Supplies
Error 6800
According to the service manual error code 6800 means that "A problem occurred in reading from or writing to the EEPROM". The suggested parts replacement is the logic board. See page 12/64 in the service manual.
You find the service manual here: http://elektrotanya.com/canon_pixma_mp560sm.pdf/download.html and the parts catalog here: http://elektrotanya.com/canon_pixma_mp560pc.pdf/download.html
For download of files from electrotanya see this post for instructions: http://www.nifty-stuff.com/forum/viewtopic.php?pid=61324#p61324
I think that turning the printer off and disconnecting power for some minutes and then reconnecting power and turning on the printer doesn't make the error go away?
I don't know if clearing the EEPROM from service mode will remove the error, but you lose the printer history and absorber counter value in doing so. You might also have to uninstall and reinstall the printer to get the display language back to English. Probably the logic board error will prevent the printer from starting, so no service mode operations will be possible?
If you want to give the service mode a try, then I recommend studying the service manual p. 47/64 to 54/64 incl and this thread: http://www.nifty-stuff.com/forum/viewtopic.php?id=7416
Nov 02, 2013 | Canon PIXMA MP510 All-In-One InkJet...
I have canon MP510 and I have a probem because my canon have a code 6800. What can I to do? Pleas for helps
Unfortunately error 6800 is an eeprom write error. You will not be able to cure this without replacing the scnt board (main board). The cost of a new board and labour would almost equate to the cost of a replacement machine. Cut your losses and buy another machine. Srri
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Green and orange light flashing and on the screen was Service Error 6800
Service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Dec 02, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Hej I get an error code 6800 Regards Ivan
Mar 20, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon mp530 printer had a check cartridge error U052, but then it changed to check printer 6800 and it won't work. is there a cure?
6800 must be EEPROM error.Try this:
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (you're still holding the POWER button during this). The printer mechanics will move momentarily. You're in SERVICE MODE now.
Press the RESUME 3 times.The lamp will alternate color with each key press.Then press POWER button.Wait 5 mins and press POWER again, the printer will turning off.
If this not help printer may need service.
Oct 15, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error message 6800 check printer
you have a ASF sheet feed unit or AP position error,
to fix it replace sheet feed unit.
Canon Tech
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
