Question about Reebok Exercise & Fitness
How do I remove the drive motor of my Reebok ice treadmill re- 10301i
    Top Expert:
  • Reebok Master
  • 12,223 Answers
Please see the video attached, and use the common sense. Happy New Year . God bless yo
Posted on Dec 31, 2012
2 Suggested Answers
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
Jan 02, 2014 | Reebok Competitor RT 5.1 SpaceSaver...
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
managua, nicaragua. c.a
Feb 17, 2012 | Reebok Exercise & Fitness
Belt slipped then speed went from 4.2 to 0.0 while motor was still running now the belt won't move at all motor runs.
Remove the motor cover and check the drive belt.. Realign the speed sensor if it has been misaligned (next to the pulley).
Dec 16, 2010 | Reebok T 1280 Treadmill
Squeaking noise from tread
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Aug 06, 2010 | Reebok Exercise & Fitness
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
Distance screen on treadmill
May 05, 2009 | Reebok Exercise & Fitness
Brand new Reebok v6.80 treadmill, trouble on start up!
I just had the same thing happen to me with the same treadmill. I called Reebok and they had me remove the motor hood. Sure enough, the bolts holding the motor had completely sheared off and the motor was lying loose in the bottom of the treadmill. They are sending a new motor and bolts and a technician to install them. They said it was probably dropped hard during shipping.
Jan 23, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
215 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
