Question about Masterbuilt 20070106 Electric Smoker
Set temperature, it goes past it, then it keeps going down until it shuts off
I set my smoker to 225, it went up to 240, then it started going down with the temperature, when it showed 190, I restarted it thinking it might help. I had to leave and when I got back (5 hours) it should have just cut off and still been hot but it was already cold and meat was not fully cooked. How do I know if it's the thermostat or the heating element?
  • Masterbuilt Master
  • 21,631 Answers
You can test the element by bypassing the thermostat. The element should come on and stay on, probably glowing cherry red. If it will continue to do that for an hour, then you know the element is good.
The problem sounds like a classic thermostat problem. It will come on from cold and up to temperature, but as it drops, the thermostat doesn't click back in because it is stuck open. Its sensitivity is gone, but when it goes cold, the temperature change is big enough to close the circuit.
Posted on Sep 17, 2017
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
ToolBoxHero
  • 171 Answers
SOURCE: 30" Masterbilt smoker won't get over 60 degrees. I
I am having the same problems with mine. I have rebuilt the connection, three times.
I am going to pull the element out and replace it with a single-burner heating element like the Proctor-Silex 34101. That will be plenty of heat for the smoking I do.
Posted on Jan 31, 2011
heatman101
  • 43501 Answers
SOURCE: In the recipe for Baby
Three hours of cooking @ 225.... start the timer after reaching temp.
heatman101
Posted on May 27, 2011
  • 4736 Answers
SOURCE: While using my Masterbuilt smoker
SgtDave - Don't feel like the Lone Ranger. There have been a bunch of people seeking either the burner element and/or the electronic controls. The burner element is available form Appliance Factory Parts, but only with the smoker box. At one time is was sold separately, but now, the element by itself is no longer available. Even Masterbuilt no longer sells just the heating element. In part, if you check your Owner's Manual or the Manufacturer's Data Plate on the smoker, take note of the Country of Origin, you'll understand why.
Wish I could have been of more help to you.
Posted on Jul 11, 2011
SOURCE: masterbuilt eletric smoker: the control panel
I have one that is 3 yrs old and just had the same problem. After reading other posts this is what I did. I removed the wood chip holder. This is accomplished by removing two phillips head screws from the holder on the right where it attaches to the inside wall. Then the are to small bolts that have to be removed where it attaches to the frame in the center. Now you should all of the heating element. Remove the two outer screws where it attaches to the back wall. Don't take out the center one, it attaches the ground wire on the other side. Tip the heating element up and gently pull it out, it won't come far and you should be able to see if one of the wires has burned through. The wire had burned off the right hand portion of the element in mine. To repair it you need to access it from the back. Take out the screws that hold the time/temp control on top. Drill out all the rivets from the back outside panel, remove the bottom screws from the drip pan holder, and pull the panel off. Towards the bottom you will see the back side of a small metal box that covers the heating element connections. Pull that box out. Get some blue or red rtv sealant from your local auto parts store Clean the area around where the element mounts on the inside, put some sealant on the mounting plate and remount it. This serves to make it water tight to help prevent corrosion inthe future. I chose the leave the connection cover off the backside. If you do that as well you might need to use small bolts to remount the element since the screws screw into that box. In order to remoun the element wire you will need a yellow male spade clip available at the auto parts store, home depot, etc. Strip about 3/8 in of the insulation of the burned wire, place it in the center of the spade clip and crimp the yellow part. Slide the clip onto the element end. Reattach the time/temp control, plug in the smoker and turn it on to see if it heats. You can lightly and quickly touch the element inside the smoker to check for heat, carefully of course so you don't get burned. Assuming it works, unplug everything, return to the back and use rtv sealant to completely cover the connections to the element. Wait for it to set up and recoat a 2nd time. Plug everything back in and do a 2 or 3 hour test run. If that goes well, apply rtv sealant to the back of the smoker and use #10 1/2in sheet metal screws to reattach the back. Good luck!
Posted on Oct 13, 2011
The exhaust smoke at the top vent of my char broil 30" digital electric smoker reads 245°, but my panelis set at 225°. Can i recalibrate temp settings
Most smoker manufacturers consider a swing of 20 degrees either way acceptably within range, so there's not necessarily a problem there. Remember that your smoker will measure differently depending on where the temp probe is. Heat rises, so it makes sense that it may be hotter at the top, especially if the ambient temperature isn't too cold. Put a cheap oven thermometer on your rack and use that to accurately read the temp where your meat will be.
Feb 18, 2018 | Grilling
Tip
Smoked meat secrets. Fall off the bone fantastic!
Here's the secret. You want to get a digital thermometer with a remote you can keep in the house that reads the air temp and meat temp of the inside of the grill so you can monitor the temps. All you care about is getting the meat's internal temp to 175F and keeping it exactly on that number. When the meat first goes in you can have the air temp around 400f but over the next 2 hours gradually lower it. You can do this in 2 steps to save yourself too much effort. As the meat's internal temp reaches 150F you need to get the air temp in the smoker to 225-250 and keep it there until the meat reaches 175. That is the temp at which the connective tissue in the meat breaks down and gives it that "falling off the bone" quality we all love. Keep the meat's internal temp at 175F until it reaches the desired tenderness. If you do that you're friends will all envy you're smoker skills. Trust me you will be amazed. Now for the vents. It's very simple, Once the coals are good and hot (they should be ash colored) then add a chunk of hickory or applewood. You can buy it at the grocery store in chunks where they sell charcoal. The set the intake vent on the bottom of the fire box to about one and a quarter inches open. Then set the chimney vent so it's only open about the width of a standard pencil. The wood will start to smoke almost immediately. Once it stops add about 8-9 more lumps of charcoal and one more lump of hardwood and just keep an eye on it. After the meat reaches the desired color and looks really savory and covered in smoke then wrap it in foil and finish it in the oven at the temps I mentioned earlier. That way you can really regulate the temp evenly and get perfectly tender smoked meat. Good Luck!
on Jul 09, 2010 | Grilling
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
The fan has auto ond on selections, the heat looks to be running fine but the fan will NOT shut off.
The thermostat needs to be set for AUTO. If you have it on auto and the fan still goes even though the heater is off then you probably have a stuck fan limit. The limit has a long probe which goes n the plenum. As the heat builds in the plenum at the start-up of a warming operation the bi-metal inside that probe slowly twists around till the temp inside is 110 degrees, the fan comes on and we have warm air in the vents. Then when we have a cozy house the heat shuts down. The fan keeps a going till the heater cools down and the bi-meta twists back around and shuts down the fan. So what goes wrong? The bi-metal simply gets hung up in that position. Tapping on the dial will sometimes release it but it will keep occurring and become aggravating. themobilian_306.jpg
These limits come in various sizes and brands but this is the most common one. If your machine is a newer model then that control board has a fried or stuck relay on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 28, 2010 | Heating & Cooling
Is there any way to increase the maximum operating temperature on the electric masterbuilt smokers w/ electronic controls?
Unfortunately no. What temperatures are you trying to reach. Most smoking of meat is done at 225-250. What is the maximum you can obtain? Keeping the unit out of the wind and cold, better insulation, stopping any leaks, is about the only way to do it.
Nov 09, 2010 | Masterbuilt 20070206 Smoker
Smoker h20 deluxe
I'm a smoker expert having entered in competitions. Thermometers built into the lid are inaccurate because you want to measure the temperature at the same level the meat is at. Heat will rise and will give you a false reading at the top of the lid. Get a digital thermometer that has a cable and a probe on the end. Cut a small potato in half and stick the probe through it so the point exits the potato and is balanced when it sits on the grill. Then run the cable outside to your thermometer. Shade the thermometer from bright sunlight. If you don't want to do this you can simply get a regular thermometer that will measure at least to 225 or more. Stick the thermometer in the top vent of the smoker or if there is no vent just drill a small hole in the lid. Put the thermometer through the vent or hole in the lid and add 10-15 degrees to allow for heat buildup. Example 240 degree thermometer temp will be about 225 at meat level. You may have to experiment with these readings. Happy smoking! Go to my favorite website for smoking.....Google search " Virtual Bullet" and you should be at the Weber Bullet site. Hank
May 10, 2010 | Char-Broil Deluxe Charcoal H2O Smoker
I was given a texan smoker
Yes you can. The digital control goes in place of the old controller and it is a un plug and replug in the ends. Make sure you keep track of what color plug in what color. Some have a purple dot to purple wire, orange dot to orange wire etc., but I don't know for sure on the older grills. Just write it down and be safe. FIRST make sure you unplug the grill before you start and DO NOT plug in till you have the new controller in place. It will short out when you touch the side if it is not unplugged.
Mar 24, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
Elements Mp4 player shuts down after little play
Mine did the same thing. What I did, and it worked well for me, was I went down the menu until the Settings, then clicked that and went down until the Power Off section. I clicked that and went to Sleep Time, and held the right button down until it was set to 240 (I think that's what the highest # is). That keeps it playing for 240 minutes, after which it automatically shuts down to save power. You have to reset this every time you turn the mp4 player back on.
Hope that helped!
~~*Holly*
Jan 09, 2009 | Audio Players & Recorders
Masterbuilt 20070106 Electric Smoker Logo
421 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
