My photocopy macheni canon ir 4570 keeps on giving the error code e0001-0002
    President:
  • 2,022 Answers
Fuser temperature too high.
Check AC driver board, shorted thermistor. Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 31, 2012
  • 452 Answers
SOURCE: My ir canon photocopier shows
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
Posted on Dec 18, 2010
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
Posted on Aug 25, 2011
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
muleskinner2
  • 270 Answers
SOURCE: Canon ImageRunner 4570 gives me an error code:E000001-0010
If after resetting the error and you still get the error code than the fixing film for the IR-4570 will have to be replaced and the error will have to again be reset. The part that is supposed to be getting hot is bad and only that part will need to be replaced.
For the IR-5070, the error code is that the heater is not getting hot. If the error has a 0000 sub code then the thermistors may need to be replaced or the DC Controller. Most likely the heater itself is not bad because thay should last the life of the copier. Try doing an error reset by going into service mode. Additioan function key, 2&8 at the same time and then Additional function key. Slect copier, then function, clear, err. If it goes back into the error the above items may need to be replaced. Good Luck. 0010 sub code is that the copier has been turned off and on without restting the error.
Posted on Oct 17, 2008
Adi_Taticu
  • 71 Answers
SOURCE: i have an error in canon photocopier IR 1210 E 245
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
Posted on Oct 25, 2009
I have canon ir 4570 copier machin it shows the error code 732-0001 . i turnedf on-off and after that it s the same errror
that error means there is no comunication between the reader and main electronic boards, get technical support
Apr 03, 2018 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
How can i fix an E007 error code on CANON IR 2022?
Ther's aproblem with fixing unit. Usualy the fixing film has to be replaced
Jul 16, 2014 | Canon iR 2022i Printer
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Mar 04, 2008 | Canon imageRUNNER 4570 Copier
794 people viewed this question
k24674
jasbo
jasbo
