Question about Husqvarna Designer I
The motor makes a whirring running noise but the needle does not go up and down
I was in the middle of sewing an embroidery. the needle stopped and the motor sounds like it is running or a fan is running. I tried turning off and restarting but it still does this. I also tried just regular sewing and it does the same thing. Is there a belt that could be broken or is it something really bad?
  • Husqvarna Master
  • 7,365 Answers
The sewing machine really needs to be serviced
Posted on Dec 31, 2012
dupina
  • 110 Answers
SOURCE: Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Posted on Dec 12, 2007
  • 192 Answers
SOURCE: Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Posted on Apr 08, 2008
SOURCE: My Rose 605 blows the overload motor fuse.
I finally fixed this machine. What was wrong was the PC board. It was very expensive to fix. Over $500.
Posted on Jun 06, 2008
kent581
  • 87 Answers
SOURCE: sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Posted on Mar 18, 2009
  • 152 Answers
SOURCE: the embroidery arm is not working properly
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
Posted on Oct 15, 2009
White Sewing machine won't start. Makes the whirring noise but will not advance fabric. I've tried moving the bobbin spool back and forth but it still won't start.
If your machine is not broken, it most likely is seized due to old oil that has hardened. How long since its last service? Refrain from trying to run the machine until the issue is resolved as it could damage the motor. or more...
Wheel on right side that controls the needle up and down is very tight...
Aug 29, 2017 | White Sewing Sewing Machines
Pfaff 1222 E Makes a whirring noise, wheel won't turn
How long has it been since it's had a thorough cleaning & oiling (including the internal moving parts)? Resist trying to run the machine if the only thing running is the motor. You could burn up the motor or possibly break a gear.
The following method has helped me rescue some frozen older Berninas (which your model seems to resemble). This method worked on all of them except one that also needed a cracked gear replaced.
It was working now it seems to be frozen the needle part wont move
Oct 31, 2016 | PfaFF Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Apr 05, 2012 | Sewing Machines
The bobbin thread nested underneath, tried to stop
Have you turned it back on once the machine has cooled down? If you have, and it still makes noise and won't stitch then I think the motor is damaged and you need to take it for repair. Does it do ordinary sewing or is the motor completely uncooperative?
Meantime, take the bobbin assembly apart and clean it out - ask for more instructions if you don't know how to do this. Be sure both the top thread and bobbin threads are threaded correctly and clicked into their respective tensions. Did you "park" the embroidery unit before turning the machine off? You need to do this, if the machine will do it that is.
You will need to take the machine in to be checked even if you do get it working. Any major problem with nesting - did you break needles too? - almost certainly will have put your needle assembly out - it will need re-centering.
Dec 15, 2009 | Husqvarna Designer I
Designer 1 stops sewing in the middle of long run of decorative stitch
sounds like the motor belt came off the machine, your description makes that sound exactly like what the problem is.
Aug 12, 2008 | Husqvarna Viking 1
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
216 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
