Question about CycleOps Front Hub
Grease cycleops front hub
How do I do this
  • 21 Answers
This may not be an option, the image associated with this question heading is from the earlier generation hub. The earlier generation hubs had the window slot with carbon fiber insert to match the rear cosmetics of the CycleOps Power Tap rear hub. The axle was 9 mm axle.
The new generation hubs do not have the carbon fiber insert and have a 10mm Axle
More importantly, the bearings inside are sealed 6901 cartridge bearings. These are really non-serviceable bearings. They should be removed and replaced with new cartridges.
The bearings will be measured by External Ring Diameter, Internal Ring Diameter, and width.
You'll need a bearing puller to remove and bearing press to install. This is not beyond a DIY project, but a simple labor charge at a bike shop could save you from damaging a $100.00 hub.
Posted on Jan 04, 2013
How do you repack front wheel bearings on a 98 Cherokee 4X4
OP<
Posted by J Sparacino on Aug 31, 2016
you double posted. why do that????
no, the hubs are integrated bearing hubs.
here read the parts pages,
see any tapered bearings there,
if not sold , pray tell , how can you pack the bearing not in hand.
not only that, there are like 1000000 books on how to pack front bearing, if they were removable and are not.
why not look first then post.? at car and the book, !
or read the FREE FSM, it says what ?, unbolt them
and replace the integrated hub assembly.
that is a fact. 300 times ive posted the free book, now.
and is still there, and the words still real ,still jeep words and all accurate. sigh.
below is rockautos list of after market hub assemblies.
do not get confused at those needle bearings, those are actually front axle shaft bearings, not hub wheel bearings. fact.
wheel bearing are ball or tapered rollers, to handle lateral huge loading.
http://www.rockauto.com/en/catalog/jeep,1998,cherokee,4.0l+l6,1315943,brake/wheel+hub,wheel+bearing+&+hub+assembly,1636?a=Referer+duckduckgo.com+URL+%2F
Aug 31, 2016 | 1998 Jeep Cherokee 4WD
How to fit front wheel bearings Which brand to use for quality
If the car is front wheel drive a puller is required to dismantle the hub a rather involved job better left to a mechanic .If rear wheel drive do the following. ( Applies to front wheel drive also.) Chock rear wheels,loosen front wheel nuts, jack up car, fit safety stands,remove wheel , remove grease cap from axle. remove split pin or locking nut on axle ,Remove hub, with a punch drive out the grease seal ,the tapered cone bearings can now be removed, the 2 bearing cups still in the housing will have to be pressed out ,all old grease has to be cleaned out. the new cones must be repacked with high temp bearing grease . tap in the seal with the lip facing inwards , slide on the hub fit the outer cone to the axle , the spacer and nut goes on next, tighten the nut to seat the bearings , spin the hub make sure its free to spin, back off the nut one eighth of a turn fit a new split pin or lock tab. fit grease cap and road wheel.
Jul 27, 2014 | Cars & Trucks
How to replace front wheel bearing
pull wheel remove grease cap undo carter key remove nut pull off rest of hub take bearings frt and rear out of hub clean old grease from bearings check bearing for defect install in revers order remender to install new grease in new bearings lots of grease and u will need new seals for same front and rear
Jun 14, 2014 | 2006 Suzuki Verona
2000 ford f250 front hub dry
The hub should have grease in the taper bearings that go on the stub axle. If the grease was missing and the bearings were dry and rusted then the grease seal in the hub had failed and water was let into the bearings. Replace with new bearings and repack with a water resistant grease. Fit new seal .
Apr 01, 2013 | Cars & Trucks
Front hub will not lock in on 4wd - all else works
im not familiar with truck but her are some ideas, when you say hub are you saying only one? does this truck have manual or auto hubs? If so, some times the hub grease gets to cold and will not allow the hub gears to slide or engage. Its possible that the drivetrain or 4x4 works but hub is stripped gear, use axle grease on bearings but use lithium grease on gear.
Jan 11, 2011 | 1997 Mazda Pickup
How do you remove the Hub and Rotor on a 97' F250 with Auto 4 wheel drive? I can not get the rotor to come off. I know that the hub must come with it. However, I am not sure what I have not removed in...
Section 05-03C: Wheel Hubs and Bearings, Front Wheels, 4-Wheel Drive 1997 F-250/350/Super Duty Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000 Locking Hubs, Manual
Item Part Number Description 1 3A329 Halfshaft 2 3C132 Rolling Diaphragm Seal (Axle) 3 3299 Integral Spacer Needle Bearing Seal 4 3123 Bearing, Caged Needle 5 3105 Front Wheel Spindle 6 1190 Wheel Hub Grease Seal 7 4221 Inner Wheel Bearing (with Bearing Cup 4222) 8 1102 Front Disc Brake Hub and Rotor 9 4221 Outer Wheel Bearing (with Bearing Cup 4222) 10 - Pin (Part of 1195) 11 1195 Inner Lock Nut 12 1198 Lockwasher 13 1197 Outer Lock Nut 14 - Steel Thrust Washer
(Part of 3B458) 15 - Plastic Thrust Washer
(Part of 3B458) 16 - Splined Thrust Washer
(Part of 3B458) 17 3B457 Snap Ring 18 1K105 Hub Body 19 - Lock Ring (Part of 1K106) 20 1K104 Cap 21 1K104 Capscrew A - While Rotating Front Disc Brake Hub and Rotor, Tighten Inner Lock Nut to 68 Nm (50 Lb-Ft) to Seat Bearings. Back Nut Off 90 Degrees (1/4 Turn). B - Tighten to 217-278 Nm (160-205 Lb-Ft) C - Tighten to 4-6 Nm
(35-53 Lb-In) Removal
  1. Separate cap assembly from hub body by removing the three Torx® head capscrews.
  1. Remove the lock ring seated in the groove of the front disc brake hub and rotor (1102).
  1. Remove the hub body assembly from the front disc brake hub and rotor. If the body is difficult to remove, install two capscrews and pull the body assembly out of the front disc brake hub and rotor.
Installation
  1. NOTE: Do not pack the hublock body assembly or cap with grease. Excessive grease can cause excessive dialing effort and hub failure.
    Follow removal procedure in reverse order.
  1. Tighten three Torx® head capscrews to 4-6 Nm (35-53 lb-in).
Oct 04, 2010 | 1997 Ford F250 SuperCab
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
Cycleops 2 Trainer: trainer is leaking oil...
Crank seal is away. Mine went and i had to strip the fluid2 trainer to replace it. They have a lifetime warranty so they will replace it for you.
May 16, 2010 | Fluid Cycleops 2 Trainer
Directions replace front wheel bearings on a 1985 nissan stanza?
NOTE: After the wheel bearings have been removed or replaced or the front axle has been reassembled be sure to adjust wheel bearing preload. Refer to the Adjustment service procedure below. On the 1989–92 240SX there is just one wheel bearing, pressed into the hub and no adjusting cap. Refer to the exploded views of the Front Axle Hub Assembly. Review the complete service procedure.
  1. Raise and support the vehicle safely.
  2. Remove the front wheels and the brake caliper assemblies. NOTE: Brake hoses do not need to be disconnected from the brake caliper assemblies. Make sure the brake hoses are secure and do not let caliper assemblies hang unsupported from the vehicle.
  3. Work off center hub cap by using thin tool. If necessary tap around it with a soft hammer while removing.
  4. Pry off cotter pin and take out adjusting cap and wheel bearing lock nut.
  5. Remove wheel hub with disc brake rotor from spindle with bearings installed. Remove the outer bearing from the hub.
  6. Remove inner bearing and grease seal from hub using long brass drift pin or equivalent.
  7. If it is necessary to replace the bearing outer races, drive them out of the hub with a brass drift pin and mallet.
  8. Install the outer bearing race with a tool (KV401021S0 special tool number) until it seats in the hub flush. NOTE: Place a large glob of grease into the palm of one hand and push the bearing through it with a sliding motion. The grease must be forced through the side of the bearing and in between each roller. Continue until the grease begins to ooze out the other side through the gaps between the rollers. The bearing must be completely packed with grease.
  9. Pack each wheel bearing with high temperature wheel bearing grease. Pack hub and hub cap with the recommended wheel bearing grease up to shaded portions. Refer to the illustration.
  10. Install the inner bearing and grease seal in the proper position in the hub.
  11. Install the wheel hub with disc brake rotor to the spindle.
  12. Install the outer wheel bearing, lock washer, wheel bearing lock nut, adjusting cap, cotter pin (always use a new cotter pin and O-ring for installation after adjustment), spread cotter pin then install the O-ring and dust cap.
  13. Install the brake caliper assemblies and bleed brakes if necessary. Install the front wheels.
Jun 23, 2009 | 1985 Nissan Stanza
How to change the front wheel hub for 2000 LINCOLN LS
hi you will have to remove the wheel,grease cap from the hub remove the brake caliper and move aside (do not seporate rubber line). (discard caliper bolts can not be reused) remove rotor,wheel hub retainer nut (and discard nut can not be reused) in order to remove the hub
install
hub and new nut and tighten new nut to 189-254 ft.lbs
rotor new grease cap seal
brake caliper with 2 new bolts tighten to125-170 ft.lbs
wheel tighten to85-104 ft.lbs
pump the brake pedal befor moving car
Feb 06, 2009 | 2000 Lincoln LS
CycleOps Front Hub Logo
138 people viewed this question
Top CycleOps Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a CycleOps Cycling Expert? Answer questions, earn points and help others
