Question about Lenovo IBM/Thinkcentre M55 Motherboard-43C0060
I have levovo Thinkcenter MT-T 8808-Y8V. When I switch the power On, CPU fans start with very high speed and continue till the power on. No display and No error beep. I also want toknow that where is
When I switch the power On, CPU fan starts with very high speed and continue till the power on. No display and No error beep. I also want to know that where is BIOS chip lies on this motherboard
  • 12 Answers
SOURCE: Powers on-indicator lights light up, motherboard fan runs, but do
try reseating the dimm ..
I don't see a listing in the manual for 5 beeps as you describe
Posted on Jan 08, 2009
fortozo_c
  • 23 Answers
SOURCE: Whenever I start up my Lenovo T60 it beeps twice
Generally all laptops cooling system start their fan for a second just after power on. So, if you don't notice this, it may be broken or jammed. If this is the case, you need to take apart it and inspect the fan while booting the machine. Removing the keyboard would let you see the fan. Perhaps you can check if its power cord is attached correctly. And about the error message, the BIOS is reporting this malfunction and won't load to operating system.
Thanks
Posted on Jan 28, 2011
elix0411
  • 3530 Answers
SOURCE: I press the power button, CPU fan comes on for a
Welcome to Fixya
Sound like LCD problem. Try to drain the electorstatic charge of the board for this sometimes the cause of no display while computer is turned on. I wrote a tip on how to do this. Please click here.
If this will not work then you have a bad LCD there and needs to be repaired.
Please let me know if you have further questions.
Thank you for using Fixya!
Posted on Feb 26, 2011
jntala
SOURCE: Beeping sound
I take out the ram and proceser but still beeping
Posted on May 10, 2013
  • 155 Answers
SOURCE: computer will not power up the power light just keeps flashing
Probably power supply, but you can try a different display monitor, try unplugging the hard drive. You need to see your PC go to the BIOS boot screen to do further testing.
Posted on Nov 19, 2013
Computer will not power up the power light just keeps flashing
Nov 19, 2013 | Lenovo Computers & Internet
Download motherboard driver for ibm think centre mt-m 8808
i need a driver motherboard levono thinkcenter MT-M 8808 - 9HM
Mar 28, 2012 | IBM ThinkCentre S50 8183 - P4 3 GHz...
When i power on my ibm desktop thinkcenter the cpu fan starts with a very high speed and do not proceed further.
Its Due to your Heat sink & cooling fan problem, its located on the top of the CPU. open the CPU cabinet and clean the dust, and start the computer.
May 31, 2011 | Computers & Internet
PC runs great until you power completely off. The it will take several tries of power on attempts. It will not start with the CPU fan coming on high speed. Must keep trying until low speed is heard. I...
Sounds like a problem with the power supply based on what you've written. Could be motherboard too, but Power Supply is usually the culprit.
I'd swap it out to test ;)
Jan 01, 2011 | HP Pavilion a450n PC Desktop
In my hp 61020 mt destop am facing the fan speed and noise is too high....any solution to this....
It may be just that the fan needs to be replaced.
More likely is that the computer cpu is overheating and the motherboard is ramping up the cpu fan speed to try to cool it, hence the high fan speed and consequent noise. This usually happens when the heat sink is clogged with a lot of dust. It could just be that the fan heat sink came loose.
It may be that it's just a noisy fan, in which case replace it with one that doesn't make as much noise.
Nov 17, 2010 | HP Computers & Internet
Unit cools but has only low speed. is fan bad or control board
It's either the high speed winding on the motor or the button or switch. You need to check to see if you have voltage to the high speed when you push the high speed button. If you have volts it's the motor if not it's the button or switch.
Jul 04, 2010 | Heating & Cooling
Is my cpu getting to hot my cpu fan runs in high speed a lot. do i need a bigger fan or my cpu is going bad.
Neither.
Turn the computer off.
If it is a HP laptop, remove the battery.
Disconnect the AC power.
Buy a can of compressed air, and give your computer a "blow-job",
to blow all the dust away from the heat-sink on top of the CPU,
and also, if it is a desktop, from inside the power-supply.
A layer of dust is a layer of insulation, preventing the heat-sink on top of the CPU from "radiating" the heat away from the CPU. So, your motherboard is detecting that your CPU is "too hot", and automatically speeds-up the cooling fan, to try to move the heat.
Nov 17, 2009 | Office Equipment & Supplies
Dell dimension 8400 fan runs at high speed upon power on. fan continue to increase speed very loud unable to power off with power switch
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Aug 19, 2009 | Dell Dimension 8400 PC Desktop
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
Lenovo IBM/Thinkcentre M55 Motherboard-43C0060 Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
