What is going on here? - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
I really don't know what you are showing us! Is the machine running? On what cycle? Is the drum turning?
Posted on Dec 31, 2012
1999 Cadillac Eldorado ,overheating changed thermostat , overflow cap ,no white smoke coming from exhaust.hot blowing from heater
Are the cooling fans coming on ? Go under the hood in the engine compartment , with the vehicle running have some one turn on the A/C , do you see and or hear the cooling fans come on ? Could be the coolant temperature gauge is bad ! How many miles on the vehicle ? Ever have water pump replaced ?
Check for a loss of system pressure.
Is there a loss of system pressure?
Go to Step 2 yes
Go to Step 3 no
Inspect and repair any faulty hose connections.
Does the engine still overheat?
Go to Step 3 yes
System OK
Check for low coolant protection (-37?°C/-34?°F).
Is there low coolant protection (-37?°C/-34?°F)?
Go to Step 4 yes
Go to Step 5 no
Test solution. Replace the coolant if necessary.
Go to Step 5 yes
System OK
5
Check the water pump belt for low tension.
Is the water pump belt tension too low?
Go to Step 6 yes
Go to Step 7 no
6
Replace the water pump belt tensioner.
Go to Step 7 yes
System OK
7
Check for an inoperative thermostat bypass.
Is the thermostat bypass inoperative?
Go to Step 8 yes
Go to Step 9 no
8
Replace the bypass.
Go to Step 9 yes
System OK
9
Check the water pump.
Is the water pump inoperative?
Go to Step 10 yes
Go to Step 11 no
10
Replace the water pump.
Go to Step 11 yes
System OK
11
Check the radiator fins for obstruction.
Are the radiator fins obstructed?
Go to Step 12 yes
Go to Step 13 no
12
Inspect and clean the radiator fans.
Go to Step 13 yes
System OK
13
Check the cooling system passage for obstruction.
Is the cooling system passage blocked?
Go to Step 14 yes
Go to Step 15 no
14
Inspect and flush the system. Reroute or replace the hose if necessary.
Go to Step 15 yes
System OK
15
Check the water pump belt for damage.
Is the water pump belt damaged?
Go to Step 16 yes
Go to Step 17 no
16
Replace the water pump belt.
Go to step 17 yes
System OK
17
Check the cooling fans.
Are the cooling fans inoperative?
Go to Step 18 yes
Go to Step 19 no
18
  1. Inspect the electrical connector. Replace if necessary.
  2. Does the engine still overheat?
Go to Step 19 yes
System OK
19
Check the throttle body circuit flow.
Is the throttle body circuit flow restricted?
Go to Step 20
Go to Step 21
20
  1. Inspect the orifice and associated hose. Replace if necessary.
Go to Step 21
System OK
21
Check for a stuck thermostat.
Is the thermostat stuck in the closed position?
Go to Step 22
22
Replace the thermostat.
System OK
Sep 16, 2015 | 1999 Cadillac Eldorado
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
Is PSP better than PSP go ? which one will last long?
in my opinion psp go is much better because it is lighter and more portable and it gives you more memory
COMPARISON
Screen Size - PSP Go: 3.78 inch WideScreen LCD, PSP 3000: 4.3 inch Widescreen LCD
Screen Resolution - PSP Go: 480×272 pixels, PSP 3000: 480×272 pixels
Form Factor - PSP Go: 4.8 x 2.6 x 0.6 inches, PSP 3000: 6.7 x 2.9 x 0.9 inches
Games - PSP Go: Downloadable Only, PSP 3000: UMD and Downloadable
Online Gaming - PSP Go: Infrastructure (online) and Ad Hoc, PSP 3000: Infrastructure (online) and Ad Hoc
Music - PSP Go: Yes, PSP 3000: Yes
Photos - PSP Go: Yes, PSP 3000: Yes
Movies - PSP Go: Yes, PSP 3000: Yes
Internet Browsing - PSP Go: Yes, PSP 3000: Yes
Memory - PSP Go: 16GB Built-in, expandable Memory Stick Micro supported, PSP 3000: Expandable via Memory Stick Duo
Blutooth - PSP Go: Yes, PSP 3000: No
Connect to PS3 Console? - PSP Go: Yes via Remote Play, PSP 3000: Yes via Remote Play
Store - PSP Go: PlayStation Store, PSP 3000: PlayStation Store
Skype - PSP Go: Yes, PSP 3000: Yes
Parental Controls - PSP Go: Yes, PSP 3000: Yes
Jan 20, 2011 | Sony Video Game Consoles & Games
I am having trouble with my ac and heat when i turn it on nothing comes out then when i turn it on high it makes a loud click under the passanger side glove box. it is in a big black box to the left of...
Noise from Blower Motor
  1. Inspect the air inlet grille for debris. If the grille has debris, go to step 7. If the grille is clear, go to the next step.
  2. Sit inside the vehicle, close the vehicle doors and windows, turn ON the ignition, with the engine OFF, and cycle the blower motor through all of the speeds in order to determine where and when the noise occurs. If there was noise during the blower operation, go to the next step. If there is no noise, go to step 10.
  3. Inspect for excessive vibration at each blower motor speed by feeling the blower case. If there is vibration, go to step 6. If no vibration is present, go to the next step.
  4. Listen to the blower motor at each blower speed. Is the blower motor making a squeaking or chirping noise? If yes, go to step 8. If no noise exists, go to step 10.
  5. Remove the blower motor, and inspect the blower motor and impeller for deposits of foreign material. If there is debris, go to step 7. If there is no debris, go to the next step.
  6. Inspect the blower motor for cracked blades, loose impeller retainer, or improper impeller alignment. If any of these conditions exist, go to step 8. If none of these exist, go to step 9.
  7. Remove the foreign material. When complete, go to the next step.
  8. Replace the blower motor. When the repair is complete, go to step 10.
  9. Install the blower motor. When the repair is complete, go to step 10.
  10. Operate the system in order to verify the repair. If the condition has been corrected, the repair is complete. If noise still exists, repeat the entire procedure.
Noise from A/C System NOTE: Noise from the A/C system may be heard as squealing, chirping or moaning noises, or as a vibration noise.
  1. Start the engine and ensure the A/C system is ON. If any noise is heard when the system engages, go to the next step. If no noises are heard at this point, go to step 8.
  2. With the engine OFF, inspect the drive belt for excessive wear. If the belt is excessively worn, go to step 17. If the belt is not worn, go to the next step.
  3. Inspect the drive belt tension. If the tension is correct, go to the next step. If the tension is not correct, go to step 18.
  4. Inspect the drive belt for excessive oil coverage. If the belt is covered with oil, go to step 16. If there is no oil present, go to the next step.
  5. Start the engine, ensure the A/C system is ON, and visually inspect the compressor and the clutch. If the compressor appears locked up, go to step 23. If the compressor and clutch appear okay, go to the next step.
  6. If the compressor clutch is slipping, go to step 22. If the clutch is not slipping, go to the next step.
  7. Using a stethoscope, listen to the A/C compressor for any abnormal noise. If noise appears to be caused by the compressor, go to step 14. If the compressor is not the cause of the noise, go to step 9.
  8. Does a moaning noise exist when the A/C clutch is engaged? If yes, go to the next step. If no, go the step 11.
  9. Listen to the A/C compressor components and mounting for noise concerns using a stethoscope. Are any of these components loose, damaged or excessively worn? If yes, go to step 19. If no, go to the next step.
  10. Idle the engine and engage the A/C compressor clutch. Using a stethoscope, move around the entire refrigerant plumbing system. Listening for any abnormal noises caused by a component of the A/C system touching another component. Are any of the A/C components grounding out and causing a vibration noise? If yes, go to step 21. If no, go to step 12.
  11. Does a vibration or rattle noise exist when the A/C clutch is engaged? If yes, go to the next step. If no, go to step 13.
  12. Does the noise stop when the A/C clutch is disengaged? If yes, go to step 14. If no, go to step 24.
  13. Idle the engine in PARK with the A/C compressor clutch engaged. Using a stethoscope, move around the entire A/C system testing for any abnormal noises caused by a component. Do any of the A/C components cause an abnormal noise? If yes, go to step 20. If no, go to step 24.
  14. Verify that the A/C system is properly charged. If it is properly charged, go to step 25. If not properly charged, go to the next step.
  15. Recharge the A/C system to specification. Is the abnormal compressor noise still present? If yes, go to step 23. If no, go to step 25.
  16. Repair the oil leak. When the repair is complete, go to step 25.
  17. Replace the drive belt. When the repair is complete, go to step 25.
  18. Replace the drive belt tensioner. When the repair is complete, go to step 25.
  19. Repair or replace the A/C compressor mounting component. When the repair is complete, go to step 25.
  20. Repair or replace the component that is causing the moaning concern as needed. When the repair is complete, go to step 25.
  21. Correctly route or insulate the A/C component. When the repair is complete, go to step 25.
  22. Replace the A/C compressor clutch. When the repair is complete, go to step 25.
  23. Replace the A/C compressor. When the repair is complete, go to step 25.
  24. The concern may be caused by an engine related component. If the concern is found and repaired, go to step 25.
  25. Operate the system in order to verify the repair. If the system is okay, the repair is complete. If not, repeat the entire procedure.
Noise from the HVAC Module
  1. Start the engine. Cycle through all blower speeds, A/C mode settings and temperature control settings. Determine the type of noise, whether it is a scraping, popping, ticking, clicking, chirping or groaning, or an air rush or whistle. Is a scrape or pop noise evident when selecting modes or temperature settings? If yes, go to step 5. If no, go to the next step.
  2. Is a tick/click, chirping, groaning or scraping noise present, but decreases as blower motor speed is decreased? If yes, go to step 5. If no, go to the next step.
  3. Is an air rush/whistle noise evident in all modes but not all temperature settings? If yes, go to step 5. If no, go to the next step.
  4. Is an air rush/whistle noise evident only in defrost or floor mode? If yes, go to step 5. If no, examine for other sounds, repeat step 1.
  5. Remove components as needed to access the HVAC module. When complete, go to the next step.
  6. Inspect the airflow doors for proper operation and the ducts for obstructions or foreign materials. Were any of these conditions found? If yes, go to step 9. If no, go to the next step.
  7. Inspect the mode and temperature doors and seals for warping or cracking. Are the doors in normal condition? If yes, go to step 9. If no, go to the next step.
  8. Replace the appropriate door and/or seals. When the repair is complete, go to step 10.
  9. Remove any obstructions or foreign material found. When the repair is complete, go to step 10.
  10. Install the components removed in step 5. When complete, go to the next step.
  11. Operate the system to verify the repair. If system operates without noise, the repair is complete. If noise still exists, repeat the entire procedure.
Aug 19, 2010 | 2002 Mercury Grand Marquis
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
Plz answer, thanks!!
Click the Office Button in the upper left corner. Click "Save As"
Click "Tools" and select "General Options"
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
There you can set a password to open the file or a password to modify the file.
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
Jun 25, 2008 | Microsoft Office Professional 2007 Full...
Washing Machines Logo
Top Washing Machines Experts
