Question about Dell Latitude D620 Notebook
D620 bad battery causing freeze
I have found a cause for d620 freeze...After struggling for days, I found that when the battery is removed from the laptop, it starts and runs without freezing up. E With thw battery in place, it runs for about 5 minutes before it will freeze.The battery gives no signs of being tired or defective. But is seems to tax the power enough to shut down on a posible heat related failure. Is this a known issue?
  • Dell Master
  • 7,627 Answers
Original or replacement battery? Replace battery, or, Contact Dell Support, if it's a fault or recall on the specific battery, it would be noted at Dell. There has been battery recalls, in the past, that were fire hazzards. I don't know if your battery applies? This issue COULD be dangerous, if left unattended.
Posted on Dec 31, 2012
Geekman
  • 32281 Answers
SOURCE: dell latitude d620 power on password can't remove
No need to short out any pins, shorting out pins allow you to reset the BIOS quickly. When you leave the BIOS/CMOS battery out overnight, this will reset the BIOS (you only need to leave the battery out for 1/2 + hour to do the same thing).
Posted on Mar 29, 2009
  • 202 Answers
SOURCE: Dell D620 not running on AC power
By the description of your PC and of the replacement board, it should work. But I would suggest some further checking. This is not an easy way to diagnose a repair. If you have the Service Tag(on a white label on the bottom) go to www.support.dell.com, check the warranty status, I know it's out but it will get you to where you can view the original config of your laptop. Check the list for the MB specs and compare that to the one you found online. If that checks out, I'd go for it. Another option would be to try and find a used laptop online. I've seen some newer ones on ebay that were reasonable.
Anyway, keep me posted on how it goes.
~ Spoem
Posted on Apr 09, 2009
  • 34 Answers
SOURCE: HP Lattitude D600 Laptop freezes up
It could be a number of things. . Sometimes the unit will freeze when it overheats.. Have a look around the exhaust vents and see if there is excessive dust built up around there. If you notice any, you may have to take it in to get checked. If you are tech-saavy, then take it apart and clean out the CPU fan. Also make sure that there is good airflow around the vent when operating the unit.
If this is not the case, then you should take some notes to see if there is a trend when this happens. What sort of apps are running when it freezes at the 45 min mark. Is it only on battery? If so, its possible the battery is running out of juice and the software is not throwing the correct warnings - it just freezes the machine (this is exactly what my Asus EEEPC does to me when I let it run wayyy down on the battery - it freezes. However, it warns me a few minutes ahead of time). Try yours on AC and see if it has the same problem. If not, then its likely your battery. You may need to go in and tweak your power management settings to make sure that it warns you when the battery level is low.
Posted on Apr 20, 2009
NitrusInc
  • 326 Answers
SOURCE: Will over heating cause the computer to freeze?
D610's are almost always over-heating due to simple dust build-up. Our fleet needed to be cleaned out on a regular basis. Simply grab a can of compressed air at a office-supply store, or related, and aim it straight into the bottom fan, and back vents.
Unless you have squealing or your fan is not spinning at proper speed, or at all, your parts are fine and a simple remove of dust and debris should work.
If this does not solve your issue, please let us know. If this information was helpful, please take a moment to rate this solution. Thank you.
Posted on Apr 21, 2009
bob_computer
  • 3153 Answers
SOURCE: Dell D620 power light comes on when pushed but goes out 5 sec lat
There are two common causes for this and both relate to the power supply.
First is that the connector on the main board is loose or has a bad connection
If you are proficient with a soldering iron this is an easy fix for approx $10
http://www.insidemylaptop.com/category/4-dell-laptops/
They have some very good step by step guides for replacing power sockets.
It could also be a dying power supply which is the second most common cause.
Replacements are easy to obtain and cost between $20 to $60.
If it is the PSU either get an original replacement (EBAY is best bet) or get one of the many multi laptop PSU's available but if you get the latter please make sure it carries enough or preferably MORE amperage than you need.
The old supply will have the details of both the voltage and current on it and you need to match the voltage exactly and keep the same or better current rating eg 1000 Mw or 1A or whatever it says.
Bob
Posted on Jul 31, 2010
How to remove bios password with Dell d620 ?
if it is the password that pops in blue as soon as u start up mate the best bet buy the cd from ebay i have one but i found it easier going to the computer shop cause they have the hardware to do that plus if u google it pay a company who remove bios passwords you WILL HAVE TO REGISTER WITH them but make up something cause they ONLY do it for commercially goodluck if you dont get anywhere tell me and i,ll help you ok.
Aug 27, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a 2002 K1200LT. It seems that the battery is losing voltage and does not start the bike. It is a second new battery and is charged. When charged it starts the bike ok but after a couple of days it...
It sounds like there is something draining your battery such as an alarm. I would start by charging the battery up and checking the bike starts ok. Then totally isolate the battery and wait a few days. Reconnect it, does the bike start? If no, then its a bad battery (just because its new doesnt mean its good).
If you have a multimeter you can use this to find what is causing the problem. This can be acheived by putting it in series with the battery. There will be some current drain, but no more than around 50mA. If you have a larger drain then start by removing one fuse at a time and see if the current drain reduces to an acceptable level.
This should then help identify which circuit is giving you the problem.
Oct 14, 2013 | 2008 BMW K 1200 GT
Had a sudden powercut, after which my Dell Latitude d620 began stuttering. I mean the computer slightly pauses about every 2.5 seconds. What is causing this?
Remove the main battery and unplug the charger from the computer for about thirty minutes to get rid of any residual charge and unplug charger from receptical. The laptop has taken a spike which can scamble the main processor causing all kinds of symptoms. If there is no change, the charger should be checked or subbed for another, if it goes deeper it will involve motherboard issues.
Mar 03, 2012 | Dell Latitude D620 Notebook
Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
Two possible causes for flashing Amber battery light.
1) Your battery won't charge and needs to be replaced.
2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
Oct 20, 2011 | Dell Latitude D620 Notebook
Phone keeps freezing on and even removing the battery will not make it work again. Nokia 6700 slide
Good day. remove the battery and memory card, then try to open after awhile. Erase all the files from your phone memory, never use the phone memory for storing large files, this may cause your phone of getting slow and get freeze. If still not work, I advice you to reformat your phone for better cure. Thanks
Sep 15, 2011 | Nokia 6700 Slide Cell Phone
I have a ge dryer model dvl223eb6ww. It has gotten very noisy and sounds like somwthings rubbing or its struggling . any ideas?
Check the belt tensioners pulley for the bearing in the idler pulley does freeze upo causing a thumping sound when they go bad
Jun 15, 2010 | GE DVL223EBWW Electric Dryer
Dell latitude d620 power on password can't remove
Mar 29, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Audio and Video (Windows Media, Real Player, and player software) freezes up
can u speedtest your bandwith just compare Dell Latitude D620 & Dimension 8400 check ther bandwith.
Mar 13, 2008 | Dell Latitude D620 Notebook
Dell Latitude D620 what anti-virus you install this pc?
if ther an antivirus program just configure your realtime setting.
Mar 07, 2008 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
