Question about LG Televison & Video
My murphy tv stays on standby how do i turn it off
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
s_haywood10
SOURCE: murphy 32 " tv/dvd when switched on screen comes
INVETER BOARD IS FAULTY
Posted on Aug 06, 2012
Murphy tv and dvd combined model: 32883 the problem is that when u turn it on by the power button on the remote control it stays on for a few seconds and then goes off the stand by light stays on.
its busted
and with a name like Murphy its hopeless, hahahahah
it shuts off due to gross errors inside, some which prevent fires
or electrical shock.
get it serviced? is the only fix.
you can google all day
but whats wrong, will be many things,
all cause are found using TOOLS.
that you do not have
http://www.tomsguide.com/answers/id-2692682/murphy-model-32883-lcd-switch-standby-light-flashes-10x.html
Jan 24, 2017 | Power Computers & Internet
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Stays on standby no picture or sound
When a Sony TV has just the STANDBY LED lit and nothing is flashing (An error code) then the TV is in PC standby meaning usually that there is no signal coming in on the PC input (Computer). Turn on the computer that's attached to fix this. If this is incorrect then you will need to use your remote and select the correct tv signal input for your particular setup.
Good Luck!
Rich Lilja
Mar 23, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Murphy 32 " tv/dvd when switched on screen comes
Please include the model no. of your unit to assist you on the symptoms.
Oct 23, 2011 | Televison & Video
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
LCD tv won't power on...
The power board is dead,replaced the board.Well get the power back.Tries Shopjimmy.com,Ebay.com for the part.
Jan 26, 2010 | Televison & Video
Standby light is on but tv won't turn on/stay on
The standby light is on. When i try to turn on the tv the power on light flashes a couple of times then goes back to standby...
Jan 03, 2010 | Emerson LC320EM8 32 in. LCD TV
My TV will turn on and stay on standby. You can
the video IC is broke so... buy a new and change it
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
Computer Repairing
Computer Repairing
