Question about Locks & Locksmithing
Onity ht24 turns green but does not unlock door?
My onity ht24 turns green when card is inserted into the reader. But it seems like the latch is not activated and does not unlock the door.
SOURCE: mikomi card reader
I also have one of these readers and bought a 4gig SD card. When I put it into the reader, I also had the same error message to insert a card into the drive. I was told by a colleague that the reader may not be able to read a card bigger than 2 gigs.
Posted on Apr 18, 2008
  • 4 Answers
SOURCE: unlocking oven door??
Try pressing STOP/CLEAR, then pressing in and holding the door switch plunger for 6 seconds on the upper right hand corner of the door.
Posted on Sep 17, 2008
  • 61 Answers
SOURCE: card reader door will not stay closed
most experts hide where you buy these parts. next you need to know what part number it is. sorry, i have not found the website that sells stuff i will call junk little pieces. you'll have trouble i believe
Posted on Jun 01, 2009
shynysaxena
  • 166 Answers
SOURCE: How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
wcilocktek
  • 7 Answers
SOURCE: Onity lock ht24--In the test
Chris, The HT 24 Lock does not have a keyboard so this test is not relevant to your lock. This test feature is for an Onity lock with a numbered keypad.
Hope this helps. If you have any more problems or questions you can call me or send an email through my web site.
Ken Croston 407 814 4974
www.ElectronicLocksmith.com
Posted on Nov 04, 2010
I hear click , but can not lock the door
Need more information. Try lifting up on the handle when you card the lock. A worn or broken clutch assembly is a common issue with older TESA/Onity HT24 locks.
Mar 09, 2015 | Locks & Locksmithing
Why does my onity ht24 lock not open when the handle is pushed down? it always works when the handle is lifted up but almost never when the handle is pushed down.
The lever return spring might be weak or broken. Lift the lever slightly and then push down. If it opens, that's the problem. If it still won't open, something else might be broken or badly worn. The handle is pushed down far more often than it's pulled up.
Apr 29, 2014 | Locks & Locksmithing
I have onity lock after using guest key card i am getting green light but handle is not opening door
Listen if you hear a click sound when you get the green light. Try to turn the handle up. If you hear a click, and you can open the door when you turn the handle up, you have a bad clutch kit. If you do not hear a click, then your circuit board needs replaced.
Call if you have any more questions or need to order the parts.
Thanks,
Ken Croston Jr.
407-814-4974
Feb 28, 2014 | Cars & Trucks
Qnity ht24
Sounds like the battery board needs replaced. If a solder point is bad, it can loose time or programming when the door slams. Sometimes it is due to corrosion from being on an exterior property. Feel free to call if you have any other questions or need the board.
407-814-4974
Feb 17, 2014 | Locks & Locksmithing
I have 5 brand new TESA Onity locks that will not work after I program the lock.Just blinks red when I insert the key in it.
This page is for Onity's Supplies and Services:
http://www.onity.com/support/supplies-and-services/
It is the only source of contact information that I could find toward solving your problem.
I suggest that you contact them through the phone number listed on this page. For your convenience,
By Phone: 1-800-749-2983
By Email: OnityBusinessServices@utc.com
Jul 27, 2011 | Locks & Locksmithing
I have a Onity Advance lock and the green light is flashing at a very rapid rate. The lock stays in the open position all the time and never goes to the secured position. So you can just press the handle...
I am going to guess that this lock is a common door.
The flashing green and staying unlocked indicates that this lock is in "Office Mode"
If a master key has office mode capability, and the lock program has office mode capability, the lock can be permantly unlocked by "double dipping the key". It can be put back in to regular mode by "double dipping the key" again. This will only work if the master has the "office mode" capability.
Thanks,
Ken Croston
407 814 4974
Jul 13, 2011 | Locks & Locksmithing
Onity lock ht24--In the test mode, what does "FF" mean when keyboard test is run?
Nov 03, 2010 | Locks & Locksmithing
Unlocking oven door??
Sep 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Mikomi card reader
you may have to check the manufacturers website for a vista compatible driver (as it seems that the generic driver is not working here.)
Oct 22, 2007 | Electronics - Others
Locks & Locksmithing Logo
70 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
