Question about Energy Savers Coralife Turbo Sea High Pressure Pump1740P ()
Who to repair the circuit of energy saver bulb?
What are the common defects in the circuit? please show with pictures & how to replace it with new one?
Why the bulbs are so common in villages, while in cities we use CFL and LED lamps?
Yes, people are still using incandescent bulbs in villages. This maybe because they are not aware of it or they are not able to afford it. Though the use of CFLs or LEDs will benefit them in the long run, they are not educated about the importance of energy saving therefore; they tend to always buy normal bulbs only. However it could be that outside of the metro areas, power generation rates are government subsidized, so there is not much incentive to switch over to save money. The older bulbs will no longer be manufactured starting next year, so eventually the village stores won't have them to sell to customers as warehouse supplies deplete.
Energy Saving LED
Feb 15, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
The photo slide show is now blank The photo show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed...
Welcome to Fixya
Try this procedure to drain the static energy of the phone.
1. unplug power from base
2. unplug phone connection from base
3. remove cover and battery from handset
4. wait 10 minutes
5. put battery back, reattach phone connection and power
Thank you for using Fixya!
Jul 22, 2011 | GE Lands Phones
All of a sudden the light on our hunter celing fan is flashing like a strobe light
Three possibility for the strobe problem:
1. Loose wire connection. Shut down the circuit breaker, pull down the switch, open the ceiling fan cover and check for any loose wiring connected to the main bulb, If there isnt any, remove the bulb and spray WD-40 or contact cleaner to the receptacle. Replace the bulb.
2. Replace the bulb with a new one. Preferably incandescent or a warm white energy saver.
3. There maybe ghosts fooling around. (I'm kidding)
Hope this helps,
levibit
Dec 18, 2010 | Hunter (25417) Ceiling Fan
The power/standby light blinks red 6 times on my Sony KF50WE610 and there is no picture. What does this error code mean?
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Not a DIY fix
Please rate my help++++Thanks for using FIXYA
Aug 01, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My projection tv has sound but no picture?
The HV and HOT have failed. This is a very common failure for rptv sets. The HV is derived from the Horizontal Output Transistor and is distributed sequentially to the three projection tubes; there is much power and energy going on when it is working properly; when it fails you will know it in many ways not unlike exactly what you have witnessed. The repairs will be over $200 but should be less than $400; all depends on the exact components (there are over 200 of them in the two circuits mentioned) that are defective. You will need a tv tech to make the repairs. First it will be necessary to determine exactly which components have failed and why; then they must be procured and replaced. Not a trivial matter; but that is what us tv techs do.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Philips 60P8341 60" Rear Projection...
KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Apr 05, 2010 | KitchenAid Dishwashers
TOSHIBA 62HM15A
It sounds like you need to replace the lamp. Take the lamp assembly out and inspect it. It will have a white smokey look or may be cracked if it is bad.
Aug 02, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Red Color is not showing up.
THIS TV HAS KNOWN PROBLEMS WITH PICTURE TUBE FAILURES AND I WILL PREDICT THAT AT SOME TIME IN THE FUTURE EVEN IF YOU GET IT REPAIRED NOW, ONE OF THE REMAINING TUBES WILL START GIVING YOU PROBLEMS. YOU HAVE THREE TUBES IN THIS UNIT (RED,GREEN & BLUE) AND THE RED TUBE IS DEFECTIVE. SORRY FOR THE NEWS BUT JUST TRYING TO SAVE YOU THE ULTIMATE COST FOR REPAIRS, FOR A PICTURE TUBE REPLACEMENT AND SUBSEQUENT SET UP IS A MAJOR & COSTLY REPAIR.
HOPE THIS HELPS
Jul 07, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Energy Savers Coralife Turbo Sea High Pressure Pump1740P () Logo
47 people viewed this question
Top Energy Savers Garden Experts
Dennis Key
Dennis Key
john h
Are you an Energy Savers Garden Expert? Answer questions, earn points and help others
