Question about Cell Phones
I have nokia n8 but sim problem i can't find rst point on board please help me
Please help me http://www.google.com/imgres?hl=en&tbo=d&biw=1152&bih=763&tbm=isch&tbnid=0ddQWfCvkd3h_M:&imgrefurl=http://gsmmilon.blogspot.com/2012/05/nokia-n8-insert-sim-solution.html&docid=qUOofPvQD8b0KM&imgurl=http://1.bp.blogspot.com/-odCPv8QbRTU/T7c7lVt3sPI/AAAAAAAABJk/gKVVuOvAcEA/s400/n8%252BInsert%252BSim2.jpg&w=380&h=261&ei=mHnhULjQHojNtAbdnICIAw&zoom=1&iact=hc&vpx=663&vpy=127&dur=329&hovh=186&hovw=271&tx=125&ty=82&sig=116537267914565227853&page=1&tbnh=132&tbnw=210&start=0&ndsp=23&ved=1t:429,r:3,s:0,i:97
  • 9 more comments
  • zohaib mukhtar Dec 31, 2012
    i cant fine rst point please help me please
    i cant find rst point please help me please
    http://www.google.com/imgres?hl=en&tbo=d...
    rst green point under the i.c on this image but i need another side rst point
    please find rst point with out under ic
    please tell me
    find dlue point without under ic
    find blue point
    please tell me now what should i do
  • zohaib mukhtar Jan 04, 2013
    tell me brothers..................
  • 6 Answers
SOURCE: Nokia 6500s-1 undo restriction code
Dear Sir / Madam,
My hand set is NOKIA 6500s-1 , not NOKIA 3200
can you please help me as i have a NOKIA 6500s-1 handset of UK and I want to insert another network SIM . and when I insert other SIM it asks for Restriction code. Please help me . this is the detail of mobile
NOKIA 6500s-1
V04.81
RM-240
(c) Nokia
Varant:01.06
IMEI: 353076027844417
Language: V 04.81
Service by United Kingdom-3
Contact me at: sufi_miah@fastmail.co.uk
Posted on Sep 14, 2008
SOURCE: Restriction code for NOKIA 6500s-1
n6500s1
Posted on Sep 21, 2008
SOURCE: http://www.nodevice.com/driver/MOTOS.../get39407.h...
no connect with pc
Posted on Jul 27, 2010
hi i've 6500s_1 bt ths time ma mob.has locked n so i want restriction code my imei no.is356400024976443
Posted on Oct 30, 2010
  • 4102 Answers
SOURCE: i have inserted micro SD
Hi, god what a nightmare your going to be lucky to get it out without taking the phone apart and even taking it apart wont give you much more chance of getting it out.
here are a few things you could try
1, hold the phone in the palm of one of your hands then with the sim card slot facing down hit the phone into the palm of your other hand as if your trying to shock the mem card back out of the slot, doing this wont cause any damage to the phone as the palm of your hand will cushion the shock, doing this a few times may force the mem card out of the sim card slot enough for you to get hold of it, you will need to hit it into the palm of your hand a few times so that it moves a bit each time getting closer to the end, make sure the slot if facing down and is the part thats hitting the palm of your other hand.
2 use 2 small pins or needles and slide one either side of the memory card and try and work it up a bit at a time you may do it this way but it will be quite hard and a long slow job.
3. if the above to options fail then what you can try is using a vac to **** it out put an attatchment on the end of the vac to make it smaller then use this to **** the mem card out doing this may also get it out but remember you will have to dig the memory card back out of the vac if it does come out and you want to use it again
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Posted on Dec 15, 2010
My nokia n8 working only offline mode .not orking in genral mode how to repar
maybe check ur sim slot or try ur sim to other phone if is no signal ur problems its in sim if not at same try to hard format ur n8
If you're unfortunate enough to encounter a problem on your Nokia N8, a hard reset maybe what you need to do. This wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it. It's also useful if you're also unfortunate enough to have to send away your Nokia N8 for repair or exchange, or maybe in future you maybe selling it and don't want your information/details/media stored onto your device for someone else to access.
Hopefully unlike the N97, the N8 will not encounter hard-reset bugs where we constantly have to hard reset.
To hard reset the Nokia N8:
1) Turn off your phone
2) Hold "Volume Down + Camera Key + Menu Key" and press power button until your phone vibrates.
or try this one
How to Master Reset Nokia N8 do the Factory Default Setting?
If our Nokia N8 have problem such as hang or not responding or slow or stuck or have problem or frozen, then what we can do is try to restart the phone first to erase all temporary file and clean the cache. If the Nokia N8 problem still there then the last thing we can try is to do Master Reset to Factory Default Nokia N8 with safety way.
#Option 1, Hard Reset Nokia N8 with Menu Setting:
If we still can access the menu, then do this step:
  1. Go to Setting Menu
  2. Choose Phone
  3. Choose Phone Management
  4. Choose Factory Setting, after that choose Delete Data and Restore
  5. The Nokia N8 will reset all data for factory default, please remember before doing this step for always backup any important data before it deleted.
#Option 2, Hard Reset Nokia N8 with Hardware Key Button:
If we can not access the menu with screen, or the LCD is not responding, we have to hard reset Nokia N8 with secret button key:
  1. Make sure you understand that all data will be deleted, so do backup as you can
  2. Turn off the Nokia N8
  3. Press the Hardware key together: Volume Down Button + Camera Button + Menu Button
  4. Still continue the no.3 step (do not release), continue with pressing Power Buttonwait until the phone vibrate to start the factory reset Nokia N8 automatically.
#Option 3, Hard Reset Nokia N8 with Secret Code and Phone Lock Code:
If we want to format Nokia N8 with security code, try this :
  1. Make sure you already backup all important data before do the factory reset
  2. From the Phone Positions, type : *#7370#, after that press YES
  3. It will ask the Phone Lock Code, if you never change it, the default Phone Code of Nokia N8 is 12345
  4. What about if we forget the Phone Lock Code of Nokia N8: We suggest to bring the Nokia N8 to nearest Nokia service center.
May 07, 2014 | Nokia N8 Cell Phone
I want my phone unlocking to t-mobile
Hi, You can't unlock your Nokia N8 for free. But you can unlock it at affordable cost from www.wickedunlock.com/nokia-n8/rs11wp9/ You haven't mentioned your country too. Anyway you can visit this site to get your mobile unlocked. This site provides unlock code for certain country's T-Mobile network.
STEPS FOR UNLOCKING NOKIA N8
1 - Switch on your Nokia N8 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N8.
3 - Compose #pw+CODE+1#.
4 - The Nokia N8 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N8 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Oct 04, 2012 | Nokia N8 Cell Phone
How do i unlock my nokia n8 mobile from contract with tesco mobile....
You can unlock a Nokia N8 locked to Tesco network using unlock code. You can get the unlock code from www.superunlockcodes.com/nokia-n8/rs12wp9/ at low cost. All the best mate.
Aug 02, 2012 | Nokia N8 Cell Phone
How do i replace the sim card slot tray in my nokia n8?
Here visit this n8 sim card slot pin replacement - Nokia N8 - iFixit this may help.But if you are a technician remove the sim case by using soldering Iron (Micro pit) , put the new one and solder it in the hole at the end of the connector.But make sure that you should do it slowly to avoid lost of circuit on the motherboard.Good lcuk
Feb 16, 2012 | Nokia N8 Cell Phone
How do i unlock
To unlock the Nokia N8 easily use the unlock code,get the unlock code from the site Onlinegsmunlock.com/nokia/rs7wp8/ and unlock it from Network Lock.Follow the instruction below and unlock it step by step.
Nokia N8 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N8 mobile phone, your phone may get hard locked and sometimes become unusable.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N
Jan 10, 2012 | Nokia N8 Cell Phone
My n8 keeps saying sim not valid no matter what sim i use can you help please
my dear,
the sim port of the phone is bad and needs to be replaced.
visit a specialist near you for parts replacement...
THANK YOU FOR CHOOSING FIXYA
Nov 27, 2011 | Cell Phones
I have a nokia n8 cannot unlock it tried several times what can be done to unlock it
Have you tried how many times please specify.You have tried 5 times means You cannot Unlock it...Because Nokia has only 5 Unlocking tries,You need to flash it after missed the tries.,if you not missed five attempts means You can Unlock it simply,you have tried what method?
You can unlock it simply using the unlock code,You can get the Unlock code from here Theunlockarena.com and Unlock it from Network Lock,then you use any GSM Network Sim card....You can enter the code correctly using the Unlocking instructions below,But specify the Network lock,country to get the code,Because CDMA Network won't be get Unlocked ,only GSM Network lock can be unlocked.
Nokia N8 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia N8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N8 mobile phone, your phone may get hard locked and sometimes become unusable.
The CODE you need to enter is the unique unlock code for your Nokia N8
Aug 21, 2011 | Nokia 6500 Slide Cellular Phone
I have Nokia N8 sim lock, please provide me unlocking code. Its IEMI : 356237044690285 network : 3 uk please send unlock code to my email: sanaullahbaqi@gmail.com i will be very thank full to you. ...
For the best place to get the unlocking code for your Nokia mobile,
Just visit this site http://www.prounlocking.com/nokia-n8/rs8wp9/
In this site just give your details of the mobile like IMEI number, country & network lock after that within a short period you receive a unlock code for your nokia mobile ..........After you unlock your phone, you can use it with any other network's sim card.
Jul 10, 2011 | Nokia Cell Phones
Cell Phones Logo
1,411 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
