Copies are very dark; almost grey
It is a Mita DC 1205 copier that was given to us. Had been work OK until the toner bucket was full and needed to be emptied. New toner leaves the copies black/grey and unreadable.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
You need a service engineer to clean and service your copier.
Posted on Jan 19, 2009
Copies come out with dark/grey streaks on both edges and a lot of black dust inside the front cover
hi there . sevsral rssons cause that . first you have to clean the toner tank which located down of the drum unit if you dont have the experiance you have to call your technical to do it for you .
another propable reason the drum unit need to clean and you will get it out any way in the first step
Aug 21, 2015 | Kyocera Mita KM-1650 All-In-One Printer
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I darken copies?
Dear Eric Smith,
i think it is control pannel board issue is there....
Jun 25, 2014 | Kyocera Mita Toner for DC-1460 & DC-1470...
Printout showing grey print background
Sounds like you are not using genuine Kyocera toner.
Try using new toner can take a few hundred copies to work through the machine.
May 07, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Black stripe in middle of copies 1/2'' thick whole page
Most likely it is a bad drum cleaning blade. It will need to be replaced. This machine is old...good luck.
Jun 25, 2009 | Kyocera Mita Office Equipment & Supplies
On normal contract my copies are very dark.
The optical area of the copier need some cleaning. Consult a technician for support. This is a minor problem.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
139 people viewed this question
jasbo
jasbo
