Question about Toshiba Satellite L500 Series Notebook
My toshiba L505-GS5035 is working fine on the battery, but it accept no pwer from the ac adapter. I measured the output off the adapter and it is 19v as it should be.
  • Mohamed Elmasry Dec 31, 2012
    I appreciate your assistance. thanks.
  • max carson
    max carson Dec 31, 2012
    Thanks, hope I was of some assistance.
  • Toshiba Master
  • 7,627 Answers
Perhaps the AC jack is damaged due to pulling on the cord. Is the battery charging?
Posted on Dec 31, 2012
  • 3 more comments
    the ac jack looks fine and provide the required voltage. also add that both dc-in and battery indicators are off
  • max carson
    Not the plug that inserts into the AC jack, the AC jack that is attached to the mobo. Open the laptop and test the Power in, with the AC cord plugged in follow the circuit, using a multimeter, to the mobo. Somewhere will be a open.
  • max carson
    When you boot on battery, what is the power info in the Tray Notification Area? Battery % dropping?
    Yes the battery % is dropping
  • max carson
    I would suspect the AC jack Mobo connection has been damaged, but I can be sure, may be a power component.
RescueTechLA
  • 2653 Answers
SOURCE: Toshiba Satellite A105-S4048 problem with AC
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Posted on Mar 10, 2009
  • 357 Answers
SOURCE: toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Posted on Mar 15, 2009
leecom72
  • 4806 Answers
SOURCE: I bought a replacement battery for my toshiba
The voltage is right but amperage is wrong so yes send the battery back and have them send you a battery with the right amperage.
You should be able to use the laptop on AC power for the time being until you receive the replacement battery.
Make sure you tell them the correct voltage and amperage so the don't make the same mistake again.
Good luck and thanks for choosing FixYa!!
Posted on Jun 12, 2009
  • 70 Answers
SOURCE: I have a toshiba satellite P205-S6267. It works
call toshiba tech support or replace
Posted on Oct 31, 2009
SOURCE: no power or lights to toshiba nb205-n210 netbook
Maybe your motherboard is fried. If you know for a fact that the power cord is good and that the DC Jack on the motherboard is good but nothing is happening then the board is just gone.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Posted on Apr 05, 2012
The non replacable battery on my Toshiba CL 151 B1204X will not charge or operate on battery
the battery problem arise vy bad battery or incompatible battery. also there may error on charge circuit. to check pls remove the battery and plug ac adapter , close the lid and turn it , check battery outer 2 pins on the laptop by multi meter ,it have to be set up 1or 2 volt than the battery output current.
but measure DC Volt near 19V. or laptop input DC voltage pls check the battery charge circuit and repair, also pls plug the battery to another compatible laptop and check.
Sep 25, 2017 | Toshiba Computers & Internet
Toshiba 1905-s301 wont run on just ac power
Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
Dec 18, 2013 | Toshiba Satellite 1905-S301...
To install web cam for my toshiba satelite l505
Connect webcam o computer, Operating system should detect it and load driver, update driver after install. Load disc if camera came with software,
Nov 19, 2012 | Toshiba Satelite 4000CDS Laptop AC Power...
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
I have a Toshiba U500 00X laptop with 19V power supply which I do not have with me at the moment. I do have an ASUS 19V AC adapter with positive terminal on the inside of the circular plug. The diagram on...
Hi, what your toshiba laptop model and asus laptop model? You can use the asus ac adapter on your toshiba laptop only if the folllowing three conditions are met:
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
For the specifications of the two adapters, you may check it here:
http://www.chargerbuy.com, then decide if it will work or not.
Jul 07, 2011 | Computers & Internet
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
When i plug my charger in to my satalite L655 and turn it on. An orange light flashes.
Hello, stoneyless
The orange flashing you are referring to means that your battery is currently out of power. I would recommend trying a friends laptop charger (same brand and model) to rule out the charger, if you know the borrowed charger is in working condition and your pc still doesn't power on then you may blame the battery. From that point i would send it in Toshiba for a replacement battery AND charger (if still under warrenty). if warrenty is no longer viable you would have no choice but to find a suitable replacement for either the charger or battery. OR you can buy the same Laptop and take out the battery and laptop cable and return the laptop with the faulty equipment.
Feb 15, 2011 | Toshiba Satellite(R) L655-S5115 Laptop...
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
My charger does not power up my Toshiba Satellite A305, is it the motherboard?
Have you tried running it without the battery?
  • If this works, then the battery has died. Replace it or run on p/s alone.
  • If not, and the power supply is definitely working, then the laptop itself needs repair.
Apr 07, 2010 | Toshiba Satellite (K000004080) Motherboard
Toshiba Satellite L500 Series Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
