My memory is almost full, can this stop disc drive from working?
    New Friend:
    Problem Solver:
  • 7 Answers
Yes, just get rid of things that you don't need to stop it
Posted on Dec 31, 2012
I can't play any games on mmy360
Are you referring to your xbox won't read game disc, or it won't load any downloaded game on your xbox and games on disc?
If it is your disc drive, this may be a major issue to the point where your disc drive no longer works, and you will have to take it in somewhere to get it replaced, or it could just be that your disc drive is dirty and you simple just need to clean the disc tray off.
If it isn't loading any games at all, you may just have a stalled xbox and need to turn it off and give it a minute or two. If that doesn't happen to be the case, your storage on the xbox could be full, causing your xbox to run slower and not cooperate. If it is full I would suggest in deleting memory of any useless apps or games, or invest in purchasing external hard drive or a larger memory Universal Serial Bus.
Now this is the final possible solution I could give you, if it is a disc problem. This is could be extremely difficult to do, but from personal experience 9/10 times it works.
Make sure to start with no disc in the drive and the Xbox is turned on. And you have a blunt object like your controller.
1. Turn the Xbox on its side laying down
2. Open the disc drive and put your disc in. Now close it.
3. Now while your xbox is trying to read the disc, just simply starting lightly-medium strength hit the top of your xbox in the general area of where the disc is until the xbox can read it or declares it can't.
This is won't necessarily work first try, but although it sounds stupid it does work for me.
May 23, 2014 | Video Game Consoles & Games
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
Disc c is showing full of memory and everything goes downloaded in this disc but it has no space other volume are free..so what i do
Usually the C drive is your main drive on your computer. The C hard disk drive (HDD) contains space measured in gigabytes, for example 500GB means 500 gigabytes of data that you can store on this HDD.
If the C drive on your system is showing full, then it is time to backup some of your data to another HDD usually an external HDD, that you can purchase at locations such as CompUSA or Best Buy.
The other volumes you refer to are internal HDD then you're in luck. Move some of your data from your C HDD to your other HDD.
Remember that after a certain point, a HDD may stop responding or respond very slowly when it is almost completely full.
Let me know if this helps out.
Feb 12, 2012 | Computers & Internet
I replaced my memory but my disc is still saying no room
Your computer _permanently_ stores files (including music and videos) on your disk-drive,
even after you turn the computer off. The disk-drive can become "full".
Your computer also has RAM ("Random Access Memory") that is used _only_ while your computer is running. If you run too many simultaneous programs, the RAM can become "full".
When you turn the computer off, the contents of the RAM are forfeited.
So, where are you getting the "full" message?
> replaced my memory ...
Did you replace with an item of the _same_ size, or with a _larger_ item?
How large was the original? How large is the replacement?
Jul 12, 2011 | Gateway MX8738 Notebook
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
My ccd-u mouse has stopped working.mouse came with floppy disc so can,t down load driver to my laptop, it was working ok but then stopped thanks
FInd a computer with a floppy-drive and a USB port.
Insert the diskette, and copy all the files to a USB memory-stick connected into the USB--port.
Move the USB memory-stick to your laptop, and connect it.
Access the device-drivers on that device.
Nov 21, 2010 | Computers & Internet
How do I empty the Lexar memory stick to create more room?
if you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Jul 10, 2010 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Disk is full of pics now saying format now
You can "format", which will erase all your photos on the disc, or you can buy more recording discs.
Jim Hart
Jun 20, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Memory low for unknown reason
when you reformated the drive you must not have deleted all partitions , otherwise you would have all the disc space minus the operating system , so check and make sure all partitions made were deleted and the full size of the disc is available for the new installation
Dec 11, 2008 | HP Pavilion dv6000z Notebook
"NO DISC" reading
Try this CD realignment process built into the Sharp XL HP505: Have unit off.
Hol down the square (stop) button and the X-BASS button while pressing the ON button. This starts the CD TEST. press play, the memory, then memory, memory, memory, adjustment lights will come on the screen. FOF, TOF, TBAL, TGAN, FGAN, RFLS. press cd1 - track 4, press cd2 - track 9, press cd3 - track 15. Press square (Stop).
If all the cd trays are full, then will light up . This worked for me.
Aug 02, 2008 | Sharp XL-HP505 CD Shelf System
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
