Question about BBB BCP-21 Microboard wired cycling computer
Bbb microboard bcp-21 specification sheet
Looking for figures on wheel circumference
What are both types of factory radio speaker wires for a 2003 Cadillac Seville the color codes
Okay Carol Crutchfield,
BBB Industries does have your entertainment drawings... three significantly complete 2003 Seville sheets (popular USA cars).
(Registration is required)
Seville = 3 diagrams... DeVille = 2 diagrams.
Else to get these detailed drawings your are looking at buying the FACTORY+WORKSHOP+2003+Seville+manual
(not cheap (if even available)).
BBB Industries Premium Alternators Starters Power Steering Products
Jul 30, 2016 | Cadillac Cars & Trucks
2003 Pontiac Grand Am a/c will only blow cold when engine cooling line is crimped closed ?
You need to figure out what your heater thermostat valve looks like... locate it & replace it... (or figure out why it is not working).
Blend door/baffle... control solenoid.. whatever!!
At rock auto (below)...
Also check out BBB industries for your wiring diagrams...
http://www.rockauto.com/en/catalog/pontiac,2003,grand+am,3.4l+v6,1410994,heat+&+air+conditioning
May 25, 2016 | 2003 Pontiac Grand Am
27000km best fuel usage 11.4 L/100 no joy from Mazda Aust. Put 285/70 17 tyres 14.3L/100
Putting different tyres on will alter the accuracy of the speedo and the recording of distance, so I wouldn't pay much attention the fuel economy. For example, a single revolution of the axle will remain constant regardless of the wheel size, but the revolution of the wheel versus distance traveled will vary depending on the diameter of the tyre fitted. If the new tyre was, say 10 cms circumference larger, then the car will travel 10cms further each full revolution (that is 100 meters every 1000 turns. If your speedo sensor is determined by the number of revolutions of the axle, then every 10,000 turns you will have travelled a kilometer more than with the old tyre size (less if the circumference is smaller). The figures you give convert to (UK) 25 mpg dropping to 20 mpg with the new tyres. Does seem poor consumption figures for a small car, but if a big engined truck that might be acceptable. All depends on how you drive it as well.
Feb 08, 2016 | Mazda Cars & Trucks
As a contestant on a televised game show, Toby gets to spin the big prize wheel, which has a radius of 2 meters. What is the prize wheel's circumference?
If the radius of the wheel is 2 meters, the diameter is 4 meters and the circumference of the same wheel is 12.5663 meters
Dec 02, 2015 | Office Equipment & Supplies
15" circle what is outside measurement
If you would like to know the circumference of a 15" diameter circle this is the formula:
circumference = radius x 2 x pi
circumference = diameter x pi
in our case:
circumference = 15" x 3,14
circumference = 47 ,1" (that's 119,634 cm)
May 06, 2014 | Cars & Trucks
Want to assign another extension to access another extensions voicemail box on a Norstar CIS system
Configuration/Sets/BBB/LineAccess/LineAssignment:
Assign the Line XXX to BBB as Appear and Ring or Ring Only (on intercom key)
Now the line rings on both sets
Administration/Capabilities/Sets/ AAA & BBB:
-Change AAA\'s Forward No Answer Ring count to 4 rings
-Change BBB\'s Forward No Answer Ring count to 3 rings
-Obviously make sure the Forward No Answer is pointing to the DN of the voice mail system on both sets
-Make sure Forward Busy is set to Non on both sets
Because the ring count is shorter on BBB all calls will dump in the mailbox of BBB
Nov 30, 2012 | NorStar M7324 Telephone
I have a Carrier humidifier model #HUMCCLBP2217-A. It appears to be working, but every time it shuts off it emits a very loud "thump". The noise is loud enough to wake me up at night. I have...
Do you feel like looking at the humidifier yourself?
You can open the door on the unit, while the furnace is running--
The humidifier is usually installed in the return air duct, so there will be a sucking of air into the open door, when you open it.
There is usually a large wheel, with a wet pad wrapped around the circumference.
This wheel rotates slowly, and picks up water from the sump-- does everything look and sound quiet as it runs? -- The float valve has to open and close, to c ontrol the leve of water in the sump-- (The pool of water the wheel runs the mat thru--
Possibly the valve shutting off, could make a plumbing BANG-- you could duplicate that, by lifting the float mechanism and stopping the water-- does that make the noise?
If you can reach and operate the Humidistat control from near the humidifier, do so a few time-- or Have someone cycle the humidistat a few times, and you listen for that sound--
Is it in the humidifier itself, or the duct work nearby?
It might be that the humidistat wheel scrapes against the side of the sheet metal duct work? -- Sounds travel a long ways in metal duct work!
Let us know if this helps
Mack B
Jan 19, 2011 | Carrier SBP Humidifier
I need the instruction sheet for the Hot Wheels Fireball racing set.
go call prduct service or look up the product and on ehow they might have directions
Aug 21, 2010 | Mattel Hot Wheels Fireball Raceway Playset...
On starting a mesage comes on the lcd screen saying 17 wheels. What does this mean?
The instrument cluster on that bike was used on the G650 X Challenge and G650 X moto as well as the X Country.
You can change the calibration to accomodate the 21" front wheel used on the G650 X Challenge. This determines circumference of the wheel for calibration of the odometer and speedometer.
Dealer should have set it prior to delivery of the bike.
Aug 07, 2010 | 2008 BMW G 650 Xcountry
BBB BCP-21 Microboard wired cycling computer Logo
43 people viewed this question
Top BBB Cycling Experts
John Egan
John Egan
Are you a BBB Cycling Expert? Answer questions, earn points and help others
