Question about Magic Sing Along Consumer Microphone
Our wireless microphone TKM-370P doesnt work the lights on the microphone is on but not on the WOW Premium
How to repair the blinking red light in my wow premium?TKM-340P.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Dec 19, 2016 | Televison & Video
"tkm-360p wow mabuhay,if turn on the main switch
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 06, 2014 | Televison & Video
What type of pickup is in the mike
EC2/58, which includes the world-famous Shure SM58 cardioid
dynamic microphone.
• EC2/87, which includes Shure's SM87 supercardioid condenser
microphone.
• EC2/Beta 58, which features Shure's premium supercardioid dynamic
Beta 58 vocal microphone.
• EC2/Beta 87, which features Shure's premium supercardioid
condenser Beta 87 vocal microphone.
You can look you do a search. Just put in the mic model in the search bar.
You can Y
Jun 11, 2014 | Shure Audio Players & Recorders
My mow videoke premium tkm-370p wo concerto pro 2 mic delay what to do?
HELLO KRIS if your batteries are ok
adjust from the main menu and make some test to check if your voice is not delaying
adjust the tempo from 9 left too slow from 9 to right faster
best regards antonio
Dec 29, 2013 | Audio Players & Recorders
My wow premium karaoke does not load
hell l your problem seems to be its out of FRECUENCY and is not aligned if you turn it on a lamp in the reception must lit
if it doesnt thats the problem of course the baterries are new right
your antonio
Dec 27, 2013 | Magic Sing Along Consumer Microphone
Ricketfish srs wow - mic is not working
  • Press the PWR button on the wireless receiver to turn the unit on. The headset has a sleep/standby mode feature to preserve battery life. The unit goes into sleep mode if there's no input for 3 minutes.
  • Twist the tip of the microphone so the sound holes face your mouth.
  • Position the microphone several inches away from your mouth so it does not overload when you speak. Try to balance the microphone position and the volume setting for optimum voice level.
  • Press the ALL MUTE button (the Rocketfish logo) on the left side of the headset once to make sure that the All Mute function is not activated. The LED on the wireless receiver will light red when All Mute is activated.
  • Make sure that the volume on the wireless receiver is not turned down or muted. The LED on the wireless receiver will light orange when Mute is activated.
  • Rotate the CHAT VOLUME dial on the wireless receiver to control the chat volume.
  • Make sure the USB cable is connected to both the wireless transmitter and your device.
  • Make sure that all connections are correct and secure. Sometimes a cable may appear to be connected but it may not be pressed in all the way.
  • Make sure that the wireless receiver batteries are installed correctly. See Question 19.
  • Make sure that the wireless receiver batteries do not need replacing.
  • Make sure that the microphone isn't plugged into the Line In port (or vice versa).
  • Make sure the headphone jack is pushed all the way into the port.
  • If you're using an Xbox 360
    • Make sure the wireless receiver is connected to the Xbox 360 controller using the supplied chat cable. On the wireless receiver, press firmly, so no part of the silver jack is showing. This tight connection helps to make sure the cable does not fall out during gaming.
    • Try a different Xbox controller.
    • Try recording a message to a friend by selecting My Friends, Send a Message, then Add Voice. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
  • Try testing the microphone by connecting the headset to a smart phone and make a test call or record a memo. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
If these steps don't work, then I would advise seeking replacement.
Jan 21, 2013 | Rocketfish Srs Wow Wireless Gaming Headset...
I have a new GE Ergonomic Wireless Mini Mouse - Model 98811. Can't get it recognized by my computer.
Be sure to push the connect button on the mouse and squeeze the button on the part that plugs into your USB port.
Sep 05, 2009 | GE Wireless Optical Mouse
Magic Sing Along Consumer Microphone Logo
83 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
