Error code u51 canon mp520
Error code u51 printhead not installed
  • 121 Answers
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
You'll probably need to replace the whole printhead.  It's a bit of a job on that machine
Posted on Oct 27, 2007
  • 96 Answers
SOURCE: kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Posted on Jul 21, 2008
  • 3 Answers
SOURCE: canon ipf8000 error code
Hold down the roll/media button and the info button while turning on, wait about 10 seconds and release roll/info buttons. You should get an S in the upper right corner. That puts you in service mode. Push menu then scroll down to maintenance then right arrow to head replacement. To get out of service mode turn off.
Posted on Jan 26, 2009
taiso67s75
SOURCE: Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Posted on Sep 11, 2009
  • 421 Answers
SOURCE: Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Posted on Jan 08, 2010
Canon mp520 wont print black
Hi
Confirm the cartridge installations.
If good,try cleaning the 'printhead'
Mar 02, 2012 | Epson Stylus Photo RX580 All-In-One...
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Error code 5700
the error code you have supplied does not provide enough information to resolve this issue.
download and install this small repair utility from Canon for your printer-
http://software.canon-europe.com/software/0038012_0010487.asp?model=
follow the on-screen instructions and it will diagnose your issue and provide a solution.
if this does not resolve your problem reply to this post with the result of the software's diagnosis.
//javaftper
Aug 01, 2010 | Canon PIXMA MP520 InkJet Printer
Canon pixma mp520.when i inserted inkjets it says printhead is not installed.what is this?and how can i install?
this is a common problem it might be that your computer has not recognized that there is something new to install
1. go to your control panel on your start menu
2.then go to add remove hardware
3.click on the program that you want to remove
4. uninstall it and follow the directions on the screen very carefully
5.then put your cd back in and let it run and then follow every thing exactly as it says
Hope that this helps!
Jul 15, 2010 | Canon PIXMA MP520 InkJet Printer
Error code 6500
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error reading GA80 appears on screen for canon printer PRIXMA MP5
Hello Leslie,
Here is a link to the MP520 Support Page:
Canon MP520
Manuals and guides are available on the Drivers & Downloads tab.
Thaks for using Fixya.
Sep 01, 2009 | Canon Office Equipment & Supplies
Power down
try removing the printhead and turning on power, if it works you need a new printhead.
QY6-0070-000 around $40.00
Jun 18, 2009 | Canon PIXMA MP520 InkJet Printer
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
Feb 28, 2009 | Canon MP520 All-In-One InkJet Photo...
ERROR 5700 ON MP520 PRINTER
Hello Sir,
Just re-install the printer driver of the software. U have the printer software cd. Just reinstall it. It will solve the problem. ok
Thanks
Good luck
Feb 20, 2008 | Canon MP520 All-In-One InkJet Photo...
198 people viewed this question
k24674
jasbo
jasbo
