Question about Marantz Audio Players & Recorders
Marantz cd player no disc
Marantz 74CD10/00B No disc message after inserting cd
SOURCE: Marantz CDR 615: Msg: ''No CD''
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
Posted on Aug 16, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
djcliff
SOURCE: Solve Problem Stanton S-550 dual Cd player
Same problamo........CD player mechanism needs replacement in my case!.....It could be a flexwire (a belt like flat cable inside your CD player connects motherboard and CD lense), check that out!
Posted on Nov 10, 2009
SOURCE: Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
Posted on May 07, 2010
  • 99 Answers
SOURCE: CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Posted on Sep 12, 2010
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
No dics display
That means it can not focus on the disc or that you are using the wrong disc type like a DVD in a CD player. Try cleaning the lens.
Dec 21, 2012 | Marantz SA8260 CD Player
When I insert a blank disk, Im getting a message saying "No audio". and nothing will record. Wot to do???
It's a data disc, not the required CDR-AUDIO or -MUSIC disk it needs to record.
Feb 16, 2011 | Marantz DR-700 CD Player
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Mar 10, 2009 | Marantz Audio Players & Recorders
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
